I often hear about setting the pressure within certain ranges, depending upon the paint brand and intended result. I have been using a porter cable small compressor which has been very satisfactory for it's intended purpose and also very good for air brushing. The problem I have is that in every forum, with regard to spray painting models there is usuall some referance to 10 or 15 psi. My results using these settings have been less then satisfactory. I find that, with the compressor in question, my best results are somewhere in the 20 to 40 psi range. My question is, are there any other modelers out there who are dealing with similar issues.
The result, of course is the main concern, and to that end I really don't care what pressure it takes but because I use 3 differnt brands of paint, vallejo, testors and tamaya, thinning and spraying become complexed. I suppose if I stuck to one brand my issues would disappear but unfortunately finding the appropriate color at times, becomes the priority. I would be interested in hearing what others have to say.
thanks,
rbtvgo
