To me, it sounds like the setting solution "softened" the Future where the decal was. I'd let it sit and dry, and the staining should go away. If it's the "problem" that I've run in to, the clouding should clear up as the decal dries. If you still have a bit of haze, a bit more Future should clear it up.
Here's an example of what I'm talking about. I think it's the same thing you're talking about.
You can see in this second picture that things "cleared-up" (pun intended) once the decal dried.
I don't know if we're talking about the same thing, but I hope his helps.
Cheers,
-O
