Accurate Miniatures SBD-3 Question/Problem
    October 2006
Posted by Youputz on Wednesday, September 14, 2016 9:24 PM
Hi Guys,
Started building an Accurate Miniatures SBD with my son.  I had bought it a few years back at Hobby Lobby.  Best I can tell its from a 2005 boxing
https://www.scalemates.com/kits/186971-accurate-miniatures-480311-sbd-3-dauntless
So it seems to have several quality problems.  Cowling/gun fairing doesn't fit, and the clear parts sprue is just totally wrong, from some other plane with a much longer canopy, like the Devastator.
So what are the options to get the correct parts here?  At least a workable canopy? Anybody do customer service for them?
Thanks!
Jeff
    March 2009
Posted by wolfhammer1 on Wednesday, September 14, 2016 10:49 PM
Jeff, is the part number on the sprue for your model 3411-2001?  I have the Battle of the Coral Sea boxing of the SBD-3 and the biggest difference should be mine has a single 30 cal in the rear cockpit, and I'm guessing yours has a dual mount.  They should have the same clear parts, and if so, they have both open and closed canopies included.  If so, its the right sprue.  Having not built mine, I'm not sure about the cowling.  Is there anyone else out there with some experience?
Hope this helped.  John
    October 2006
Posted by Youputz on Wednesday, September 14, 2016 11:00 PM
Thanks for the help.  The part number on mine is 0200-2000.  It's just obviously the wrong sprue was put into the box.  It's an inch longer that what it shoudl be, and has 10 window sections.  It looks like its from a Vindicator, or one of the trainers that has a long canopy.
I'm sure just a packaging mistake.  Was mostly wondering if the company that took them over would support it.  If it comes to it I suppose I'll cobble something together out of the wrong parts/spares and hang this thing from the cieling where you can't see it!
It's a shame, because it seems like a really nice kit otherwise.
cml
    March 2007
Posted by cml on Thursday, September 15, 2016 12:17 AM
Disclaimer: This is all 'If I Recall Correctly' from a post on this forum some years ago.
Pretty sure this was a quality control issue when it was boxed at AM.
I think the longer cowl was meant to go into a later version or something like that.  Some people on here indicated their kits game with an additional sprue with the correct part, whilst others were just packed and shipped incorrectly.
Academy bought out the moldings from AM and (i think) some people have had some success emailing Academy for the replacement part - but this was some years ago. They may no longer be willing to do this.  Unfortunately i don't know what the part number is that you would need from Academy.
So...i probably haven't helped at all, but maybe shed some light on this issue.
Re: the Clear parts - no idea, i haven't seen that issue come up previously.
Chris
cml
    March 2007
Posted by cml on Thursday, September 15, 2016 12:24 AM
Had a look back through the forums, this is the thread i was talking about:
http://cs.finescale.com/fsm/modeling_subjects/f/2/t/160714.aspx?page=1
My memory betrays me - in the end, the modeller (Lawdog) was lucky enough to have somebody cast a new part for him.
Sorry, but i have no real solutions for you, but wish you all the best in (hopefully) finding a part you can use or cobbling one together.
Chris
    January 2015
Posted by GreenStyrene48 on Thursday, September 15, 2016 1:19 PM
The gun cover sounds like the mix and match parts problem some of these kits had, in the yellow box.  They needed the SBD-5 twin guns and they forgot to change out all the SBD-5 cowling parts.  If you cut the part in half you can sand down the back edge of the front half until it fits.
As as for the clear parts, all the Accurate Min Dauntless kits had the same sprue.  There have been some eBay sellers with cheap kits with no decals. One even had the sprues for sale individually.
Eduard recently released a version of the Dauntless kit so you might be able to get clear parts from them too. Academy might be worth a try too.
cml
    March 2007
Posted by cml on Thursday, September 15, 2016 6:39 PM
GreenStyrene48
Thanks for the tip GreenStyrene. I'll have to remember this when i eventually get to mine.
Chris
    September 2005
Posted by richs26 on Thursday, September 15, 2016 9:13 PM
Squadron has a canopy set for $7.95.
WIP:  Monogram 1/72 B-26 (Snaptite) as 73rd BS B-26, 40-1408, torpedo bomber attempt on Ryujo
Monogram 1/72 B-26 (Snaptite) as 22nd BG B-26, 7-Mile Drome, New Guinea
Minicraft 1/72 B-24D as LB-30, AL-613, "Tough Boy", 28th Composite Group
Posted by DDonSS3 on Friday, September 16, 2016 9:21 AM
Italeri re-released this kit also, although I don't know what it's like to get spares from them.
    May 2006
Posted by Shipwreck on Friday, September 16, 2016 4:11 PM
For your info, I have the single gun kit no.3411-0200. The clear parts assembly is no. 3411/12/20-9300. This is a great kit; sorry you have the wrong canopy! You may want to check out the possibility of a vacuum formed kit if all else fails.
On the Bench:
Revell 1/96 USS Constitution - rigging
Revell 1/48 B-1B Lancer Prep and research
Trumpeter 1/350 USS Hornet CV-8 Prep and research
    May 2006
Posted by Shipwreck on Friday, September 16, 2016 5:32 PM
Jeff, I have another possible solution. I pulled a Revell 1/48 SBD Dauntless kit no. 85-5249 out of my stash. It is a very simple kit compared to th AM kit, but the canopy is very close to the same size as the AM kit.
If you have a Michael's near by and a 40% coupon; you could have a workable canopy for less than $12!
On the Bench:
