Airfix Mossie
Airfix Mossie
Posted by Big Jake on Thursday, December 8, 2016 12:56 PM
I'm slogging through a Mossie build for a customer and am trying to figure out what these parts were used for on the plane. The instructions are no help, I figured me of you Mossie gurus might be able to help. This is for the upper nose guns.
Thanks,
Jake
http://s1299.photobucket.com/user/jbgroby/media/Monogram%20B%2029%20Model%20in%201%2048th%20scale/Airfix_zpsmezrcrqx.jpg.html?sort=3&o=0
    January 2006
Posted by Wirraway on Friday, December 9, 2016 5:40 AM
Jake, is this for the Airfix 1/24 Mossie ? I had heard that the instructions were fairly detailed ? Sorry I am no use at all, always wanted one but just cant drop the hammer on a $200+ kit.
"Growing old is inevitable; growing up is optional"
" A hobby should pass the time - not fill it"  -Norman Bates
GIF animations generator gifup.com
    November 2016
Posted by Gerhard on Thursday, December 22, 2016 1:11 AM
I can check for you tonight when I get home. I have a cut-away drawing of the Mosquito listing all parts.
    May 2004
Posted by Colin Russell on Saturday, December 24, 2016 2:54 PM
The two parts are the forward and rear gun supports. When fitted under the guns, the two spars will fit over the 4 tiny triangles moulded on the inside of the nose area. They are a real pain to fit and it is very important to take the utmost care, otherwise the gun barrels will not line up with the holes in the nose cone. I am in the middle of the same build and most of it has gone well, but the kit is a real test of patience. Hope this helps.
