Gloster E.28/39
Gloster E.28/39
Posted by jeaton01 on Friday, December 9, 2016 12:33 AM
Along with the Meteors I'm working on I have done up the Special Hobby E.28/39.  It appears I am in an early jets mode.  Will the He-178 be far down the road?  The E.28/39 is one of the better Special Hobby kits I have built.  The only issue I had was with the landing gear, if built as the parts come the airplane would look like it was on stilts.  I cut 1/4 inch off the top of the main gear struts and it still sits higher than it should.  If doing this one again I would set the trailing beam lowers at a different angle so the yokes are nearly parallel to the ground.  If the airplane had no fuel in it it might look like mine (I hope).  It was not a very large airplane.  Perhaps Dudley the new guy over inflated the struts.
The instrument panel has nice relief and detail.  I painted it black, dry brushed the details, and filled the faces with Future.  Eduard seat belts.  I blocked up the seat about 3/16", it looked way too low.
John
    January 2015
Posted by M. Brindos on Friday, December 9, 2016 1:50 AM
That is a nice clean little build you have here. We're there any more markings for this plane, or is that it?
- Mike Brindos "Lost Boy"
    March 2015
Posted by Toshi on Friday, December 9, 2016 8:08 AM
Sir, you never cease to amaze me with the unique choices of beaurtiful builds that you choose to assemble and this one does not disappoint.  You've done another fantastic job on this build sir.  I admire your work!
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
Posted by jeaton01 on Friday, December 9, 2016 10:34 AM
Mike, only two were built.  Like the XP-59 in the US its purpose was to provide a test bed for gas turbine research and was not expected to be a combat aircraft.  So, just prototype markings.
Thank you Toshi.  Be careful not to further inflate my greatly expanded ego!
John
    February 2007
Posted by Buckeye on Friday, December 9, 2016 11:30 AM
Nice build!
    November 2003
Posted by tempestjohnny on Friday, December 9, 2016 12:12 PM
Great build. Something different.
