Completed: Monogram 1/72 F-82G Twin Mustang
Posted by Bossman on Thursday, December 22, 2016 4:19 PM
Hello All,
Our local IPMS club had a Secret Santa gift exchange at the beginning of December. Being a 1/72 A/C guy - My Santa had a very nice surprise for me . . . The Monogram F-82G Twin Mustang.
It is an older kit with some nice raised detail.  Mold copyright is 1973.  Angry Hey - Wait a minute - that's not so old.
The raised detail extends into the cockpit sidwalls.  In this case though - it is so fine that I figured it would be invisible under a coat of paint.  Not to fear . . .  styrene sheet and strip stock to the rescue.
I used the raised detail as a guide for what the cockpit looked like, just duplicating it with styrene.  Maybe accurate (?)
Here's where she stands after some coats of interior green, black, dark green wash, and highlighting with a lightened interior green, and instrument panel decals . . .
Ready to be buttoned up . . .
Found out that this aircraft is only modeled after the original Mustang, but it is quite a different airframe.  It's bit bigger than the original.  Here's a shot of it compared an original "single" Mustang - an Academy P-51B.
The kit comes with 2 different and very nicely detailed pilot figures.  My friend Zuzu tells me that every time some middle aged guy starts to build a 1/72 aircaft model - a pilot figure gets his wings !   It must be true - now you've seen it on that interweb thing !
Happy Holidays to all.
Chris
Posted by Bish on Thursday, December 22, 2016 4:23 PM
Lucky guy. Off to a nice start. One of the guys did this kit in the 46 GB, looks really nice.
    March 2015
Posted by Toshi on Friday, December 23, 2016 4:44 AM
Nice secret Santa gift!  Great start!
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    September 2005
Posted by richs26 on Friday, December 23, 2016 10:04 PM
Only 20% of parts were common to the P-51 and the P/F-82.  The first 20 and the 2 prototypes were equipped with Packard Merlins, but the USAF didn't want to pay the licensing fees to Rolls-Royce, so Allison V-1710's were substituted for the rest of production.  The first 20 were relegated to trainers, so this was a rare case where the trainers were faster than production/combat models.
WIP:  Monogram 1/72 B-26 (Snaptite) as 73rd BS B-26, 40-1408, torpedo bomber attempt on Ryujo
Monogram 1/72 B-26 (Snaptite) as 22nd BG B-26, 7-Mile Drome, New Guinea
Minicraft 1/72 B-24D as LB-30, AL-613, "Tough Boy", 28th Composite Group
Posted by Bossman on Saturday, January 7, 2017 11:15 AM
Hello again all,
Some progress to report on the F-82 Twin Mustang.
The Fuselages (Fuselagi ?) are buttoned up and added to the wings.  Most everything is assembled except for the fiddley bits that will come after painting.
As always, dry fitting is a good idea before assembly,  but on this kit it really is required.  I had a few issues with the locating pins on both the fuselagi and the wings.  In some cases the pins had to be cut a bit shorter to allow the pieces to fully come together.  And in at least one case (the starboard fuselage near the tail) the pin had to be cut off clean in order to keep the parts from being offset.  These fixes were no big deal - they're easy - but they could just make things difficult for for the unsuspecting beginner.
The kit goes together fairly well, but there will be some work ahead . . .
I haven't decided on what scheme to use.  I'm not really keen on either of the two options that come with the kit.  Thinking about trying a what-iffer.
Chris
    November 2003
Posted by tempestjohnny on Sunday, January 8, 2017 5:52 AM
Chris I did a whiffer P-82 last year.  I think it looks better then the kit options. I think you should do it.
Posted by Bossman on Sunday, January 8, 2017 1:45 PM
Very nice twin mustang Johnny - I was thinking along the same lines - a blend of NMF and Olive . . .
Something like this:
With the drop tanks - I'm thinkin' these are bomber escorts - which as I understand was the original intention of the F-82 development.
Chris
    November 2003
Posted by tempestjohnny on Sunday, January 8, 2017 5:15 PM
Now you're on the right track
Posted by Bossman on Wednesday, January 11, 2017 8:16 PM
An update . . .
I decided to go through with the What-If scheme of Olive Drab over a natural metal finish.  For the NMF I decided to try something new: Rub-n-Buff paste.   I've heard that it can be done - but never heard of anyone actually going through with it.
It's a silvery paste with a viscosity a bit less than toothpaste.  You just rub it in and then polish it up with a cloth.  I tried it on a spare piece of clean styrene and it seemed to partially rub off - not good - so I figured I needed to do something to give the surface some "tooth" as they say.   I remembered using RnB in the past for drybrushing the detail on raised detail instrument panels.  It worked great.  It also seemed to stick well to dried puddles of the flat MM acrylic paint on my workbench.  So I just put a light coat of flat grey on the surfaces that I wanted to coat with RnB and set it aside to dry.  I diluted the MM acrylic down with water to reduce the chance of brush strokes.  About an hour later I was ready to apply the "Rub and Buff".
These phone camera photos are pretty bad - but they'll do for now.  The acrylic paint idea worked well enuf to grab the silver pigment.  It polished up fairly well.  It's not quite as nice as the spray cans of MM metallizer that I have used in the past - but it's OK.
This is not a great kit for applying a natural metal finish, the seams are a bit rough and there has been alot of sanding.  Every little defect shows up bright and shiny with the NMF.  "Help me Olive Drab - You're my only hope !"
I'll provide better quality pictures in the future.
Chris
Posted by Bossman on Saturday, February 4, 2017 11:26 AM
February update . . .
At about the 90% completion point with mostly just painting left.
Finished painting the Olive drab.  I wish that I darkened it a bit to give more contrast as is seen in the P-51 photo above - but this F-82 scheme is totally fictional anyway.
I varied the code numbers a bit by cutting up the decals and rearranging the order.
Used a lightened yellow for the cowl (with about ~50% white) as the photo seemed to show more of a lemon-yellow than a deeper insignia yellow.  This still needs some work. I have to figure out how I'm gonna finish the outline of the yellow area so that it blends well with yellow on the canopy frame.
Chris
    January 2015
Posted by M. Brindos on Saturday, February 4, 2017 11:40 AM
That is really looking amazing, Chris. I think you've done this kit some justice, and then some!
- Mike Brindos "Lost Boy"
    November 2003
Posted by tempestjohnny on Saturday, February 4, 2017 2:46 PM
Looks great
Posted by Bossman on Saturday, February 4, 2017 9:33 PM
Thanks Mike and Johnny !
Chris
Posted by Bossman on Saturday, February 11, 2017 1:21 PM
Here are the final glamour shots of my Monogram F-82G Twin Mustang . . .
The natural metal finished parts are Rub and Buff compound rubbed over a light grey flat MM acrylic base. (a first try for me - I will probably go back to using a rattle can of MM buffing mtallizer if I do another NMF bird)  The other colors are brush painted with MM acrylics.  The kit is a bit old - so there was some flash trimming required.  Fit was pretty good, requiring additional trimming in places.  Surface detail is a mixture of mostly raised rivets and panel lines with some recessed lines as well.  I used some decals from the kit and others from my spare decal pile to make this fictional scheme.
All in all - a nice little kit - thanks Secret Santa !
Hope you like it !
On to the next !
Chris
    January 2009
Posted by fermis on Saturday, February 11, 2017 2:35 PM
I like it...a lot!
That scheme fits it perfectly!
YesYes
Posted by Bossman on Sunday, February 12, 2017 8:56 AM
Thanks Fermis,
It was a fun build.
Chris
