Decals?
    May 2003
Decals?
Posted by qmiester on Sunday, January 1, 2017 5:17 PM
Ok, The wife and I didn't go out last night, so I decided to work at cleaning up my area in the basement.  I was taking a break (hey, I spent a good ten minutes moving stuff from point a to point b so I needed a break!).  Was next to the stash, and picked up a box to take a look inside.  It was the old Matchbox 1/32 SBD-5 Dauntless and upon opening the box, it was very clear that moisture had gotten into the box at some point, probably during the last move.  The decals may be unusable so I'm looking for some help.  Where would I find a set of decals for this thing?  I can probably paint the insignia and some of the trim colors on but would really like to find a set of replacement decals. Would Revell possibly have a set or does anyone know of a set of aftermarket decals which might available and if so, where? Thanks
Quincy
    August 2014
Posted by goldhammer on Sunday, January 1, 2017 5:24 PM
I'd plug 1/32 WWII decals into ebay and see what comes up.  Or check the offerings from different decal makers.
Worse comes to worse, might be able to save them by clearing them first then try to use them.
EDIT - looked on the bay, some Corsair sets in 1/32, but don't know how much of them would be usuable in your build.
Posted by Bish on Sunday, January 1, 2017 5:38 PM
There is a set of 32nd decals by Berna decals, but they are for a French aircrfat. Montex do masks which include insignia intended for the Trumpeter kit, but as long as you don't wnat a certain aircraft, they would work.
Posted by Tojo72 on Sunday, January 1, 2017 7:41 PM
I like to do what Goldhammer does,usually works for me,or you can even Google them.
Posted by Don Stauffer on Monday, January 2, 2017 6:43 AM
First thing I would do is test them.  Most decal sheets have unused decals.  For example, there is probably an identification of the kit, and maybe the mfgr's logo.  For arcane reasons the decal maker usually makes even that stuff as an actual decal.  Cut out one of those areas, and test it by trying to use it on some scrap.
If the decal shatters when you dip it in water, this can be fixed by painting the whole sheet with a decal film, such as that from Micro Scale.  That, however, turns the sheet into one big decal, so you have to trim each decal with a knife or scissor to cut it away from the sheet.
Another fault is that the adhesive may be gone.  While there are some fixes for this problem, they aren't easy, and if that is the problem I'd go for the aftermarket decal.  Some vendors such as Squadron, Roll Models, Sprue Bros, etc, have pretty good search engines at their site and you can narrow down the search terms pretty well.
    August 2014
Posted by goldhammer on Monday, January 2, 2017 3:02 PM
Trumpter has a 1/32 clear SBD, Midway version.  Might be able to order up a set from them or their distributor.
