1/48 F4U-4 HVAR stubs (?)
    December 2016
Posted by DanteCoz on Sunday, January 15, 2017 7:45 PM
Hello, my first post on the forum.
I am building two 1/48 Academy F4U-4's and this kit does not offer any parts for the stubs and HVARs. These will both be in Korean War markings, so I really see no way they can be omitted.
Only option I can see would be to rob a couple Tamiya F4U-1D's of theirs, but that leaves me scratching my head once again when it comes time to build them.
Does anyone in the aftermarket make these?  Does the Tamiya F4U-1 or -1A boxing include these parts?
Thanks,
Dante
    March 2009
Posted by wolfhammer1 on Tuesday, January 17, 2017 1:08 PM
Dante,
Welcome to the forums.  To answer your question, the rocket launching stubs on a Corsair are basically 2 thin streamlined tabs that hang down in line and support the rocket in 2 places.  If you can get some plastic stock about the right width as the stubs, sanding to make the shape and cutting to length should be pretty straight forward.  The only thing I'm not sure of is if there was a panel the stubs mounted to, but again that would be pretty straight forward to make.  The rockets themselves are a bit more of a challenge, though, and I'm not sure what to tell you to do there.  Sorry.
Good luck, and post pictures so we can share your achievement.  Thanks.
John
Posted by oortiz10 on Tuesday, January 17, 2017 3:14 PM
Dante, I can tell you what I did when I built mine.  (You can see it here.)  The Tamiya F-51D (Korean War boxing) has 6 (not 8) rockets included.  I had one in my stash and sourced another 2 rockets, then cut off the stubs.  I then used my Tamiya -1D Corsair to measure out the mounting plates and cut some out of thin plastic sheet.  Glued on the stubs and viola!  It's not perfect, but if you're planning on mounting rockets, it should look the part.  Oh, speaking of which, a quick Google search shows that there are plenty of aftermarket HVARs available in 1/48.  (See that here.)  Anyway, hope that helps.
Regards,
-O
-It's Omar, but they call me "O".
    July 2004
Posted by stikpusher on Tuesday, January 17, 2017 5:53 PM
Dont forget that the -4B had staggered mounting stubs. If your kit is a -4B and not a -4
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    December 2016
Posted by DanteCoz on Tuesday, January 17, 2017 9:20 PM
Thank you all for the replies. They will both be F4U-4s, not -4Bs. Turns out the Tamiya F4U-1A kit includes the stubs, even though they didn't emerge until the -1D.  I just so happen to have two of the -1A kits. I guess problem solved.
Thanks again.
    July 2004
Posted by stikpusher on Wednesday, January 18, 2017 12:37 AM
Well that's a nice discovery to find just what you needed in a different kit in your stash... and that kit does not need those parts.
       - Plankton
LSM
