C-53D (2014 new tool Airfix Dakota Mk. III)
Posted by jeaton01 on Tuesday, January 17, 2017 11:33 AM
This is the kit that was released as a new tool in 2014.  The Dakota Mk. III boxing was used but US Markings will be applied and it will be modified to be a C-53D with a single
door on the left, larger than but similar to the airline style door.  C-53's did not have a reinforced cargo floor like the C-47 with its double doors.  Out of 406 C-53’s, 159 were C-53D’s.  Another difference the D had was the side mounted seats like the C-47, other C-53’s had row type seats.  Over 10,000 C-47’s were built.
I started this kit in early November, intending it to be the tow plane that was used to tow General Pratt's CG-4A.  It was put on hold pending information from the Air Force History Office at Maxwell AFB.  It now appears that the information I need will be at least another 6 months in coming so it will be built as the C-53D at the Aerospace Museum of California which is from the same squadron that towed the Fighting Falcon carrying General Pratt and may in fact be the plane that towed it.
The kit has a very complete interior.  Painted with Model Master Interior Green and AMC Grey on the floor.  The rudder pedals are odd, at first look I thought since they were not centered I would pose the rudder to be offset the proper way, but a second look made me realize the copilot's pedals were commanding a turn one way and the pilot's the other.  Hmmm...  Seat belts are painted Tamiya Tape.
The part at the bottom of the photo is a light bar that runs down the top of the cargo compartment.  Flat white was flowed into each recess and Future was later dropped in from a twisted wire fork.
This is the last time the instrument panel will be seen.
The interior parts were not glued on to a side of the fuselage until the fuselage halves had been glued together, that way it floats into the center.  It will be sufficient to only glue the aft end anyway and that is easy to do because of the open area that later will be covered by the wing lower center section.  Some sanding had to be done on the fuselage bulkheads shown here to get the fuselage to close up.  It wasn't much but it took several trial fits to sort out where things needed to be sanded.
The wing fillets are separate parts that are glued on to the fuselage and they fit well and were easy to get in place.  Although the lower wing center section fit well to the fuselage with the spar in place, it was necessary to thin down the spar where it nests into the lower wing center section before the spar would drop into position where the upper wings would mate properly at the nacelles and leading edge, at first there was a gap at the leading edge.  The spar height was OK but the width fore and aft did not rest all the way down in the groove in the lower wing center.  When the upper wing outer panels were test fitted after the spar was thinned on the lower edge they mated very well everywhere except at the wing root, so .020 plastic card was added to the root of the upper panels to improve the fit.
No pains were taken as to shape before the plastic card was glued on.  After it had cured sufficiently it was carved to basic shape with an Exacto knife and then sanded to conform to the upper line of the wing and to clear the spar as well as to mate with the trailing edge properly.
The lower outer panels had a gap as well, the same on both sides and getting wider as they went aft.
The .020 plastic card did a good job on filling most of the gap on the upper wing roots, and had to be sanded slightly up at the front.
The two lower dental tools have been useful in filling gaps surrounded by fine detail.  They can be used to place small amounts of filler accurately and to scrape away unwanted filler while it is still fluid enough.  The top one is better for curved areas or where there is more room to work and more filler can be applied.  The less filler that goes on, the better the sanding elbow will feel.
There was some interference with the spar on the lower outer wing panels which was alleviated by removing some of this flange.  It still fit properly at the landing light area.
The remaining upper wing panel gaps were filled with Tamya putty, again as little as possible was added and filled detail was cleaned with a scriber.  No sanding has been done at this point.
The lower left wing join before sanding.
The lower right wing join after sanding.  Since there needs to be more strength than what putty will provide, after the first sanding thin CA was run down the joint and another light sanding was quickly done to remove any excess.  The fit of the front of the engine nacelles is very good, they are just hanging from a peg on the oil tanks in this photo.
The engines cylinders were painted Model Master gloss black lacquer, then the area between each set of push rod housings was filled in with Floquil Old Silver.  The same paint was used to paint the ignition ring, the reduction gear housings are Model Master Navy Gloss Grey.  Before the ignition ring and gear case were installed the cylinders were given a heavy coat of Tamiya Smoke followed by Alclad II Flat Clear.  The dishpan area behind the engine is painted Model Master Non-Buffing Stainless Steel Metalizer.  It probably will not be visible with the cowl flaps closed.
It would appear that Airfix changed their minds midstream on the astrodome.  The clear dome is cast with a tapered fit, while the fuselage is molded to accept a stepped shape.  The bottom of the astrodome was too large to fit in any part of the hole.  The Dremel stone shown has about the right drift angle and was used by turning it with the fingers, test fitting the astrodome until the fit was correct.  As can be seen, the cockpit side windows and the cabin windows have been installed.  The left cockpit window required just a bit of sanding, but the rest fit very nicely.
The first fit.  After this some research was done and it was found that the radome sat on a prominent ring above the fuselage.  Stay tuned for the Mark II radome picture.
Since this is a C-53, it is necessary to change to an airline style door.  Work is in progress.   Inset is a photo of a C-53 door.
John
Posted by jeaton01 on Tuesday, January 17, 2017 3:02 PM
It was easy enough to modify the Airfix parts and that way the other kit is still intact.  In any event, the C-53D door is supposed to be a little larger than the DC-3 door, though it is a guess on my part how much.
Here is the door with a little more work, the door is just stuck on with double sided tape here.   And a picture of the reset astrodome.   It could even stick up a little higher, looking at photos.  Very scabbed on looking.
John
    May 2009
Posted by Pawel on Tuesday, January 17, 2017 3:12 PM
Hello John!
Darn it, it's probably my browser, but I cant's see the pictures! Too bad!
Good luck with your build
Paweł
www.vietnam.net.pl
    November 2003
Posted by tempestjohnny on Tuesday, January 17, 2017 4:55 PM
John I don't think I've seen a -53 modeled before
Posted by jeaton01 on Tuesday, January 17, 2017 5:14 PM
Pawel, it's also on my website.  Can you access that?
http://www.yolo.net/%7Ejeaton/mymodels/c47/2c47/2c47.html
I haven't seen one either, John.  Perhaps it's a first!  But then, externally it's just a door.Toast
John
    March 2015
Posted by Toshi on Tuesday, January 17, 2017 6:08 PM
This almost looks like the C-54 I built not too long ago.  As usual, you're doing a fantastic job on this build!
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    July 2004
Posted by stikpusher on Tuesday, January 17, 2017 6:47 PM
I'm gonna follow this one. Anything to do with the Airborne is near and dear to my heart, especially the Normandy drop. Looking real good so far!
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by jeaton01 on Tuesday, January 17, 2017 7:08 PM
Toshi, it does have exactly the same nose, Douglas recycled that part on the DC-4/C-54.
Stik, you probably saw the CG-4A I did for the Gilder GB, if not it's here on my website:
http://www.yolo.net/%7Ejeaton/mymodels/cg4a/1cg4a/1cg4a.html
John
    July 2004
Posted by stikpusher on Tuesday, January 17, 2017 8:18 PM
J, I did indeed see your glider build and remembered discussing the McClellan C-53 with you a bit there. This will be a great companion piece.
       - Plankton
LSM
    December 2010
Posted by 1943Mike on Tuesday, January 17, 2017 11:55 PM
Following along on this interesting WIP. Your builds are always fun to watch and I do learn a thing or two from most of the talented modelers on this forum certainly including you.
The DC-3 was the first plane I ever flew in. My dad picked up my brother and me from summer camp near Keene, NH back in 1950 or '51 and flew us to LaGuardia Airport. (I lived in the city - Manhattan - back then). Pop must have asked the pilots if we could visit the cockpit and sure enough, we were up front with the pilot and co-pilot looking around at all the gauges which, if my memory serves me correctly (and that's very "iffy"), seemed like hundreds of complicated things to read. Can't imagine kids in the cockpit of commercial aircraft these days Smile.
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
    August 2013
Posted by Jay Jay on Wednesday, January 18, 2017 8:34 AM
Looks like the Doctor is in and you're performing the surgery very well indeed. Beautiful job so far.
BTW,I thought the new tool Airfix kits that everyone is raving about where supposed to be very good fitting kits. Hmmm
Posted by jeaton01 on Wednesday, January 18, 2017 12:47 PM
Mike, if I won the lottery one of the things I would do is get a DC-3 type rating.  Never had the circumstances to fly one when I was working.
Jay Jay, don't let those issues bother you, it's a very nice kit.  I put it down to Airfix just going a little to fast in design.  The fit is the Meteor F.8 is very good.  Buy Airfix, support Airfix.  They are doing good stuff.
John
Posted by jeaton01 on Monday, January 23, 2017 11:55 PM
Progress is taking place.  I had gotten dust in the cockpit transparencies when I was working on the door, well I got dust on all the transparencies, but the cargo area was no issue, I just got out the Mark V blow gun and shoved it in the door and let fly.  That cleared the cabin windows but you can guess where the dust went.  So I drilled a hole in the side of the cockpit and administered the Mark V.  Not perfect but pretty good results and no windows blew out.  This is the hole repair in progress.
Much paint has been applied.  Once again, as on the CG-4A there is the attempt to replicate haphazard work applying invasion stripes in 1/72 scale, and I think I am getting there.  The best result has been to lay some of the new Tamiya flexible tape back a bit from the desired line and then go over that with regular Tamiya tape with the edge of that at the proper edge of the stripe.  Then the edge of the second tape was distressed some so it wasn't too straight.  I like how the fuselage striping looks.  The wing striping must have been done by a better crew, it's not quite as irregular.  I had used string under the edge of the tape and had not thought of distressing the edge of the tape at that point.
John
    July 2004
Posted by stikpusher on Tuesday, January 24, 2017 12:34 AM
YesYes
Before you go adding any decals, if you plan on making her look as on the night of June5/6 then I highly suggest that you leave off any mission tally scoreboards. Those missions would not yet have been flown, and any prior flights of training drops or cargo hauling around England would not be "worthy" of a scoreboard.
       - Plankton
LSM
    March 2015
Posted by Toshi on Tuesday, January 24, 2017 5:43 AM
You are doing a superb job on this build, most imppressive!  I really like how clean the invasion stripes look!
Toshi
Posted by Bish on Tuesday, January 24, 2017 6:12 AM
Thats does look really nice. And i like your method for the invasion strips. They look not to neat but just right for the scale. Going to be trying that one.
Posted by jeaton01 on Tuesday, January 24, 2017 10:51 AM
Thanks, Bish and Toshi.
Stik, there won't be anything but the CU on the nose and the W on the tail, that's all.  And the serial on the fin.
John
    February 2006
Posted by DantheMan85 on Tuesday, January 24, 2017 11:07 AM
Nice progress, paint looks great.  Nice to see Airfix continuing to make subjects, like the Dakota Mk. III, that have been rarely touched my other model manufacturers.
On my Work Bench: Tamiya Ford GT 1/24
Up Coming: ?
    June 2008
Posted by lewbud on Thursday, January 26, 2017 7:59 PM
Interesting build subject.  This is the first build thread I've seen with the new Airfix kit.  And now for something completely different, I follow the Texas Flying Legends Museum on Facebook.  On my feed today was a post about their C-47, which turned out to be the prototype XC-53A.  Apparently, the wings were modified as well, but weren't much better than the standard wing so they were replaced and it was converted back into a C-47.  The data plates call it a XC-53A though.  So the prototype for your bird is still flying.
http://texasflyinglegends.org/index.php/2017/01/26/the-prototype-xc-53a/
Buddy- Those who say there are no stupid questions have never worked in customer service.
Posted by jeaton01 on Friday, January 27, 2017 12:16 AM
Thanks for the link, Buddy.  I have only found a couple of pictures of the C-53 doors, and what makes it even harder is that the C-53D door ws a little bigger than the airline door the other C-53's had.  And of course, what remains has either been converted to an airliner at some point or has the two cargo doors of the C-47.
John
Posted by jeaton01 on Friday, January 27, 2017 1:08 AM
Here are two photos of 42-68835 which is what I will be marking this model as, one probably taken around the time of Market Garden, and one as it is today at the Aerospace Museum of California at McClellan.
John
    June 2013
Posted by bvallot on Friday, January 27, 2017 12:11 PM
John, I just got caught up on this thread. Very cool stuff here! =] I've longed to do a C-47 at 1:48 for a while now. I've yet to do a plane with DDay stripes as I've been building all PTO aircraft (trying basically to get one of each...somehow I get a little moonstruck and repeat a few I like =]). Really like how you did them. I'm itching to try my hand at it.
Fantastic job so far.
On the bench:
Tamiya F4U-1  Kenneth Walsh
Posted by jeaton01 on Saturday, January 28, 2017 10:50 PM
Thanks, Britt.  It's all done now.  Someday I may even pull the masks off the landing lights which I quite forgot before taking the pictures.Embarrassed
All in all,the Airfix kit really looks like a Gooney to me and I like it.  The markings are for a C-53D from the 72nd Troop Carrier Squadron, and may be for the airplane that on D-Day towed the CG-4A I posted earlier.  I am still waiting to hear from the Air Force History office on that issue.  This airplane is at the Aerospace Museum of California at the former McClellan AFB.  After the war it went to American Airlines, several other owners, and eventually became a war prize for the DEA.  McClellan got it from the DEA.
The serial and the stars and bars are from the ALPS and laser printer, the rest is painted from stencils made with the Silhouette Cameo.  I really like that vinyl cutter.  The invasion stripes on the wings were done with stencils that had fine fishing leader under the edges.  On the fuselage I used the stencils to help lay out the stripes, but masking was done with yellow Tamiya tape spaced up by the new white flexible Tamiya tape which was set back some from the proper edge.  I messed with the yellow Tamiya tape edges to get an irregular edge to simulate brush painting.
With the Waco CG-4A
With the Curtiss C-46
John
    March 2015
Posted by Toshi on Saturday, January 28, 2017 11:09 PM
What a superb job!!!  I'm extremely impressed with your build.  Well, all your builds are impressive!  Thank you for sharing this with all of FSM Forum members.
Toshi
    January 2015
Posted by M. Brindos on Saturday, January 28, 2017 11:35 PM
I can't disagree with Toshi. This  is superb!
- Mike Brindos "Lost Boy"
Posted by jeaton01 on Sunday, January 29, 2017 1:03 PM
Thank you, Toshi and Mike.
John
    July 2004
Posted by stikpusher on Sunday, January 29, 2017 4:09 PM
YesYes Great finishing on this one! All you need is an airfield base and tow rope to pair it up with the CG-4A
       - Plankton
LSM
    December 2010
Posted by 1943Mike on Sunday, January 29, 2017 4:55 PM
A beautiful job on that aircraft! I love the comparison shots with the CG-4A and the C-46 as well.
Just wonderfully done!
Hector Berlioz
Posted by jeaton01 on Sunday, January 29, 2017 11:33 PM
Thanks, Mike.
stikpusher
Yeah, but then I would need at least 50 more C-47's and CG-4A's!! Not in this lifetime, except through photoshop!
John
Posted by Bish on Monday, January 30, 2017 5:12 AM
Shes a real lovely build there,you have done a great job. And nice seeing it with the glider.
