QUOTE: Originally posted by nsclcctl
Was wondering, why does the Fokker DVII have no wire supports between the wings. I thought all biplanes had the supports. What is the advantage of none and how do the wings remain stable.
Welcome to the wonderful world of WWI aviation! In a couple of weeks, I'll be starting a Roden 1/72 Fokker D.VII. Which kit are you building?
On to your question: Fokker used a much thicker wing on their later planes than most contemporary manufacturers. Compare a side profile of a D.VII to a Spad 13 and you'll see what I mean. The D.VII had a pretty thick wing spar and was braced internally (in the wing) rather than with rigging wires.
There's been a lot of discussion over the years about why early aircraft designers used thin wings and why fokker went with thicker ones, but the upshot is that thick wings were thought to cause too much drag and Fokker found that they didn't increase drag much at all. Furthermore, the thicker wing gave superior high angle of attack performance. This helped with give slower landing speeds and better dogfighting performance.
QUOTE:
With that said, when I get a camel or pup that uses the supports, what do you use to replicate them and are there any tricks?
Here are three approaches to rigging. I've not done any of them yet, but the drilling holes and using monofilament method seems to be favored by a lot of folks.
Drilling holes and threading monofilament:
http://priswell.com/uggie/Uggie2.htm
Using fuse wire (other types of wire could be used):
http://www.wwimodeler.com/esc/rig.html
More on using monofilament:
http://www.wwi-models.org/misc/rigging.html
Some folks used stretched sprue. They measure the distance snip to that size and glue the stretched sprue in there. My only problem with that method is streching the sprue to an even thickness.
Regards,
