How do I mask aircraft wheels
    March 2017
Posted by theflyingdutchman on Friday, March 10, 2017 8:29 AM
Hi I am a beginner trying to mask Revell C-130 wheels to prepare for painting.
How do I mask the wheels in such a way that the black and white don't mix?
Are any specific ways to mask the wheels?
Also, is it better to paint the wheels by brush or airbrush?
Thanks!
Tags: Help , mask , paint , wheels
Posted by jeaton01 on Friday, March 10, 2017 4:37 PM
There are a several ways I've seen.  What I used do is paint the wheel part first in most cases.  I cut a disk of Tamiya masking tape the right size using a drafting compass that has a blade in the arm for the lead, or use a drafting template.  Then I spray the tire part.  Others with steadier hands put a toothpick in the hole for the axle and turn the wheel with one had while they hold a brush in the other.  Wheels that have good definition between the wheel and tiree are easier than ones that do not.  Since I bought a scentil cutting machine I use it to make the masks, and whether I paint the wheel or the tire first depends upon the way the tire and wheel meet, and which surface is flatter so the material can conform easily.
John
Posted by Bish on Friday, March 10, 2017 4:46 PM
If i don't have ready made masks, i will spray the hub colour, white in your case, and then brush paint the tires.
    June 2014
Posted by BrandonK on Friday, March 10, 2017 4:49 PM
I too, paint the wheel color first. But, then cut a mask using a circle template you can get at any craft store, then spray the tires a light faded black. As tires are not truly black. Then unmask and hope the paint doesn't lift.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    November 2008
Posted by mrmike on Friday, March 10, 2017 5:22 PM
Like those above, I paint the hubs first. Next I'll dilute the paint for the tires to the point where it will run around the rim by capillary action and apply this with a small brush, staying away from the wheel rim itself. Depending on the size of the wheel and how distinct the hub is, I'll either continue to paint the tire or let the thin coat dry before finishing it.
Hope this will help you; I learned it here on the Forums.
    November 2003
Posted by mississippivol on Friday, March 10, 2017 8:16 PM
I have a different route, since I have trouble with white paint covering completely. I paint the black first, mask using the above mentioned circle template, then spray the white. It's kind of a poor man's preshade.
    January 2009
Posted by fermis on Friday, March 10, 2017 10:06 PM
mrmike
Ditto This is how I roll!
    March 2013
Posted by patrick206 on Friday, March 10, 2017 10:32 PM
mrmike
Me too, best and most consistent way I have found over the years.
Patrick
    November 2016
Posted by Gerhard on Saturday, March 11, 2017 6:51 AM
I paint the hubs first, then when dry, mask them with silly putty. Easy to form in the right shape, then I pain the tyre part using either a brush or spray.
    April 2016
Posted by Hodakamax on Saturday, March 11, 2017 1:24 PM
Here's my method and opinion on wheels. I'm trying to roughly figure how many wheels I've painted in my life. Most have three but a B-36 has 10 as does a B-52. Lots, I guess is the answer. Anyway every last one was painted with a brush. There is almost always a ridge separation between the hub and tire. I usually paint the center first and then the tire with a flat brush as shown in this quick shot. A little practice and you'll be amazed on how smooth an edge you can create. I you mess up, touch up the center and repeat. Actually, tires and wheels are hard to see anyway. inside and up/down positions along with wheel doors can hide small errors. Hey, even an old guy like me can roll out a good wheel!
Max
