Right paint for Natural Metal Finish on Fabric Planes
    February 2010
Posted by EBergerud on Friday, April 7, 2017 11:41 PM
Hi
Been getting interested in natural metal finish aircraft with all the new stuff coming out. However, I'm not sure how to handle fabric. I've got a Spirit of St. Louis and a Nieuport 17 asking to be built - not to mention fabric control surfaces on WWII planes. Would we be thinking of a paint pushed for the NMF market (I've got big hopes for the new Vallejo line - I don't use lacquer if possible)) or something more like the older "silver" colors. Golden has a beautiful fine silver that lays down beautifully. It doesn't emulate metal, but I think it would emulate metal paint nicely - it is one.
Thanks in advance.
Eric
Eric
A model boat is much cheaper than a real one and won't sink with you in it.
    April 2010
Posted by Theuns on Saturday, April 8, 2017 12:03 AM
Hi, the paint on fabric just had alluminium powder or paste mixed into clear dope and was spraid on to be a UV barrier.
Although it has metal in the paint, it does not look like metal atall, infact normal Humbrol 11 silver is as close as you are going to ge to the look of silver dope.
Here is a Pitts S2b bottom wing I sprayed with alluminium dope. You can see it has a semi matt sheen to it, when weathered it just becomes a little more  dull.
Theuns
Posted by Don Stauffer on Saturday, April 8, 2017 9:15 AM
I use Testors Aluminum paint.  They offer two varieties, a flat aluminum, and a just plain aluminum, which is a gloss.  You want the gloss version, not the flat.  Generally, military aircraft did not have many coats, so it is really almost an eggshell or semi-gloss, but gloss works okay- just try not to gloss clearcoat those areas.
Some private aircraft owners really pour on the coats, and the results can be pretty glossy, but that was not common on military birds.
    January 2015
Posted by M. Brindos on Saturday, April 8, 2017 10:47 AM
If you're preferring the use of Vallejo paints, then perhaps a 1:1 mix of silver and white will do the trick. I've used it before and it looks about right to the eyes.
-Mike B
- Mike Brindos "Lost Boy"
