1/72 Hobby Boss P-47D "Thunderbolt"
    May 2009
Posted by Pawel on Sunday, April 9, 2017 4:41 PM
Hello Mike!
It's always good to see you working. Those HobbyBoss kits are kinda funny - mix of great detail and ultra-tricky molding with some gross simplifications. For similar reasons to yours I have a started F-84 Thunderjet. I wish you showed some pictures in this thread, because I feel like I didn't do a Jug for too long and I'd like to know if this one is even worth looking at, or should I go straight to Tamiya. Good luck with your build and have a nice day
Paweł
www.vietnam.net.pl
Posted by Bish on Sunday, April 9, 2017 4:49 PM
I have seen there range of easy assembely kits on hannants and been put off a bit. I always view stuff like this in a bad way for some reason. So interested to see how this pans out and if i may be judging them harshly.
    January 2015
Posted by M. Brindos on Sunday, April 9, 2017 5:49 PM
- Mike Brindos "Lost Boy"
    January 2015
Posted by M. Brindos on Sunday, April 9, 2017 6:05 PM
Here are some of the sprue shots. The few EP marks are on the bay doors. There are two choices in props. The engine is alright- it lacks cooling ribs on the cylinders. The bombs, drop tanks, and wing pylons will need details added to look right, but the center line drop tank looks good enough.
The windscreen/canopy is a kinda snap-in one piece affair.
All the reviews I could find said not to bother with the pit. You can't really see anything anyways.
    January 2015
Posted by M. Brindos on Sunday, April 9, 2017 8:13 PM
This review http://gregers.fr.yuku.com/topic/4397/Hobbyboss-172-Republic-P47D-Thunderbolt-Bubbletop has been quite helpful in my decision making progress.
I think it will be helpful for you guys as well. No pictures were provided, but its very descriptive regardless.
Posted by Bish on Monday, April 10, 2017 2:25 AM
Thanks Mike, its doesn't look as bad as i had expected. Lack of pit detail was a given i think. As you say, good a a quick weekend build, and hopefullyfor getting kits into the hobby, big and small ones.
    November 2003
Posted by tempestjohnny on Monday, April 10, 2017 6:03 AM
Mike these type of kits from Hobby Boss are exactly what you said a decent weekend project. I built the Fw190D-9. It's really not that bad. Like you said very minimal interior. Exterior is decent as long as your not rivet counting
    January 2015
Posted by M. Brindos on Monday, April 10, 2017 7:09 PM
The only thing I'm not liking about this kit is the super shallow panel lines. I've given up on most of them, but I concentrated on separating the control surfaces and the cowl flaps.
I think its going to turn out okay, but not great. Still remains to be seen.
You will need a little filller along the fuselage joins. I tried getting these to go together seamlessly, but in the end I relented and pulled out the Bondo. The panel lines have suffered greatly in this area.
After scratching up a scoop for the supercharger in the cowl, I added a basic IP, IP cowl, and a gunsight. These items can be seen pretty well so I'm not regretting adding those parts.
It's all going together fairly well. I've got the landing gear and bay doors left untouched still, but I'm getting there. I may have some primer on it before the day is through.
Thanks for the interest guys. It's looking like a Jug finally lol. I'll keep you appraised.
    January 2015
Posted by M. Brindos on Tuesday, April 11, 2017 1:16 PM
Good morning, FSM.  :)
I finished up the landing gear last night. The gear doors are molded together, but a razor saw will separate them easily. There are enough locator pins on both halves to make alignment trouble free and it looks better.
I also painted the 150 gal. Centerline drop tank. I used a three rattle can (lazy) method that worked beautifully and gave me a gorgeous chrome-like finish. Ah, but then I got impatient and I have to start over again after I sand the finger prints off of it.  :(
For the rest of you fellow short cut enthusiasts, such as myself, the three rattle cans were Rustoleum flat black primer, Testors ultra gloss, followed by Rustoleum Chrome.
If I'd have let the layers cure properly and not tried to test fit it so early I'd have something nice to show you, but I screwed it up.
At least I know the process works! Lol
But this is going to take days to paint in this way so the layers cure properly.
Pictures to come later.
    May 2009
Posted by Pawel on Tuesday, April 11, 2017 1:28 PM
Hello Mike!
Sometimes I get a feeling that those spray can chrome silvers just never dry - they give you a nice shiny finish, put if you hold a part for too long or try to mask it with tape, even after several days, it's going to leave a mark.
Recently I have tried Mr Color Super Metallic Chrome Silver - now this one is expensive and maybe not the most shiny chrome out there, but its perfect for NMF aircraft and most importantly - you can really mask that stuff!
Paweł
www.vietnam.net.pl
    January 2015
Posted by M. Brindos on Tuesday, April 11, 2017 1:38 PM
The primer had about an hour to dry, the gloss had about 25 minutes, and then the chrome was given almost an hour befor I started messing with it.
I'm really sure it was my fault, Pawel. Lol
the best spray can aluminum I've ever used was Duplicolor car touch-up paint. That stuff is nearly indestructible lol!
I think I may grab another can of it. Lol
but seriously, no more rushing with metallics. I'll just end up doubling my workload lol.
    May 2009
Posted by Pawel on Tuesday, April 11, 2017 3:19 PM
Yeah, I always say good models take time! Trying to rush things (although tempting!) usually turns out the other way around... Good luck with that NMF and I look forward to seeing some nice photos! Have a nice day
Paweł
www.vietnam.net.pl
    January 2015
Posted by M. Brindos on Tuesday, April 11, 2017 8:34 PM
    January 2015
Posted by M. Brindos on Tuesday, April 11, 2017 11:51 PM
Okay, last post for tonight.
I painted the pit. Not much to see but the headrest, really. That's some dang thick glass!
So I attached the canopy and masked it. I think it's ready for primer.  :)
Posted by Bish on Wednesday, April 12, 2017 4:18 AM
Coming on nicely Mike.
    March 2015
Posted by Toshi on Wednesday, April 12, 2017 6:00 AM
Yes, I agree with Bish.  It is coming along very nicely!
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    January 2015
Posted by M. Brindos on Wednesday, April 12, 2017 12:57 PM
Thanks, Bish. Thanks, Toshi.
I noticed some gaps around the front windscreen after I posted last night. A bit of Squadron green putty worked nicely to fix that small issue.
So a little light sanding this morning and I'll be watching for a break in the weather.  :)
Stay tuned.
    January 2015
Posted by M. Brindos on Wednesday, April 12, 2017 6:54 PM
Sorry for the black on black. These pictures are dark and not too good, but hopefully you'll still see it okay.
Not sure when but I managed to fold the tail wheel over and break it.  :/
i might have to build a new one With wire to make sure it will hold up.
    February 2014
Posted by silentbob33 on Wednesday, April 12, 2017 7:04 PM
Looks like your doing a pretty good job of that kit Mike!  I needed to teach a new elective this year, so I decided to bring modeling to school.  I pitched the idea of building models and doing historical research projects on the subjects of the kits.  The administration loved the idea so I was able to purchase a bunch of these easy assembly kits.  They're not great, but pretty good for a bunch of teenagers that have never built anything before.  As an added bonus, I have a small air force in my classroom.
On my bench: Academy 1/35 UH-60L Black Hawk
    January 2015
Posted by M. Brindos on Wednesday, April 12, 2017 7:13 PM
Are there any pictures??!
I'd LOVE to see some!  :D
I've been trying to do that very same thing with my kids. Pick a model and research it.  :)
That is my favorite part of the entire experience. Finding when where and who.  :)
    February 2014
Posted by silentbob33 on Thursday, April 13, 2017 9:11 AM
I'll take a few today during my planning period.  We're going to start the last batch of kits sometime next week.  We have a lot of standardized testing right now so that's making difficult to get going.
    June 2014
Posted by BrandonK on Thursday, April 13, 2017 9:46 AM
That looks awesome. Great work on such a tiny kit.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    January 2015
Posted by M. Brindos on Thursday, April 13, 2017 12:36 PM
silentbob33
I think that's a little exciting. Finding out who gives it some effort and shows some talent. :)
Seeing who gets hooked on the history or just the build itself.
Watching the "light" turn on has got to be a smal thrill! Especially these days when electronics are what we put in our faces so much of the time.
I kinda envy you a little lol.
Pictures when or if can find the time.  Please?  :)
    February 2014
Posted by silentbob33 on Thursday, April 13, 2017 12:43 PM
It is a thrill.  Some of the kids are really enjoying it and getting into it.  It's also amusing to see them push through the frustration of certain parts of the build.  They tend to have the most difficulty with decals.  I've jumped in and helped when they ask, but the decals in these kits are really hit or miss.  Hope you've got some good ones in your kit.
I've taken a couple of pictures, but I want to pull the best ones out and get some good pics of those too.  Photobucket is blocked at school so I won't be able to post them until I get home.
Sorry if this has hijacked your thread a bit.
    January 2015
Posted by M. Brindos on Thursday, April 13, 2017 12:45 PM
Thanks BK. It's not that tiny, but the 1/144 P-47 I have put aside is tiny though! It's got wing root issues I have to figure out and it's been on the SoD for months lol.
This kit is pretty rugged in most respects. The landing gear are the weakest parts of the assembly. That tail wheel certainly proves that I think lol.
The one piece fuselage and solid wings make this a really heavy model for its size. Like I said in the beginning, it's very much like an up-sized 1/144 kit.
Next up is the silver finish. I've got a plan that should work. I've just never done it with metallics before, so this should be interesting.
Stay tuned!  :)
    January 2015
Posted by M. Brindos on Thursday, April 13, 2017 12:53 PM
silentbob33
No, this is really fascinating to me! Hijack away!!
Decals need patience. That is a test all by itself lol. Getting them to lay down properly without silvering is no easy task!
I assume you provide a few basics and lots of advice, tricks, and tips for those who want to do more than just slap them together and be done. Am I correct?
This is an assignment I would've aced back in school. Lol
    February 2014
Posted by silentbob33 on Thursday, April 13, 2017 6:08 PM
M. Brindos
That's right.  I've given them the basics and encourage them to read the instructions and I make do with paints, the colors aren't all correct, but I'd rather stress the fun aspects of the build with them.  There are a few that I give tips to and I can tell they appreciate it.  Somehow, only this picture saved on my phone so I'll have to get some more on Monday.  Sorry it has to be a tease.
These are the Hobby Boss Easy Assembly P-40B, F4U, P-51C, Hurricane, Spitfire, and Typhoon.  All in 1/72.  They also just finished kits of the La-7, Yak-3, and P-39, but the picture didn't save of those ones.
We also took a small field trip to the local airport back in February.  There's an aircraft painting business there that was putting the finishing touches on the CAF's P-51C.  As an extra treat there was also an F4U that came in just a day or two before we got there.  It was really cool to see the kids appreciate seeing the real thing after they'd built it.  Before the end of the year we'll also be taking a field trip to the Air Zoo in Kalamazoo.
    January 2015
Posted by M. Brindos on Thursday, April 13, 2017 6:30 PM
Alright. That is awesome!
I think the impact of this is going to be tremendous.
It really does look like you have a small Air Force in your classroom. Those look pretty good as well.
I hope this is something you can continue to do.  :D
Id love to see more when you can find them lol. I'll grant you a free pass to hijack this thread at any time with more on this subject.  :)
I love this topic.
    November 2003
Posted by tempestjohnny on Friday, April 14, 2017 4:43 AM
M. Brindos
I love this topic.
Bob that is a great idea for the kids. Looks like they did a decent job on the kits. I give you permission to hijack Mike's thread tooStick out tongueSorry Mike
