RAF Eurofighter Typhoon paint question
    June 2004
Posted by seasick on Monday, May 1, 2017 3:04 PM
I'm building a RAF Eurofighter and the painting instructions are only for Revell paints. I researched a little and found the color in is British standard camoflauge gray (BS 381 626).
What Tamiya or Model masters colors are the best match for this color?
Chasing the ultimate build.
Posted by Bish on Monday, May 1, 2017 3:14 PM
According to my paiunt convertor and useing Xtracolour as the standard, for tamiya you can use XF-19 and for MM 2037.
Also found this on Britmodeler which lists a number of paints for differant areas. It does not list MM as that is not avaliable in the UK.
http://www.britmodeller.com/forums/index.php?/topic/64436-raf-typhoon-colours/
    June 2004
Posted by seasick on Monday, May 1, 2017 6:53 PM
Thanks.
    January 2013
Posted by BlackSheepTwoOneFour on Monday, May 1, 2017 8:02 PM
This is my go-to paint converter chart:
www.paint4models.com
Posted by Bish on Tuesday, May 2, 2017 2:05 AM
Yep, same here.
