Help need instructions and a 1/48 P-47 HS prop
    November 2003
Posted by tempestjohnny on Monday, May 1, 2017 7:40 PM
Anyone have the instructions to the Accurate Miniatures Il-2 with skis. Mine have step 1,2,7,8,9. No 3,4,5,6. Thanks
Also looking for a Hamilton Standard prop for a Thunderbolt. I know there is aftermarket but I can't remember by who
Posted by jeaton01 on Monday, May 1, 2017 9:06 PM
Ultracast makes a resin prop:
http://www.ultracast.ca/products/48/103/default.htm
I have the instructions for the IL-2, kits 3407 and 3409, but I don't think either's the ski version, John.  Might be the same in those areas.
Just checked, 3407 has ski's, it is an IL-2 where the 3409 is the later IL2-M3.
John
GAF
    June 2012
Posted by GAF on Monday, May 1, 2017 9:09 PM
TJ,
What scale prop?
Gary
    November 2003
Posted by tempestjohnny on Monday, May 1, 2017 9:34 PM
48th. Thanks
GAF
    June 2012
Posted by GAF on Tuesday, May 2, 2017 11:27 AM
TJ,
This thread may help.
http://cs.finescale.com/fsm/modeling_subjects/f/2/t/148245.aspx
I have a couple of Tamiya P-47s, but they're in a box in storage.  If no one else responds I can see if I can dig them out and get you a spare prop.
You might want to change the title of this thread to say what kind of prop you need.
You might get more responses that way as P-47 props in 1/48 are fairly common.
Smile
Gary
Posted by waikong on Tuesday, May 2, 2017 11:32 AM
I have that kit, I can scan them in and email it to you. Just msg me your email, I can probably get it out by tomorrow.
    November 2003
Posted by tempestjohnny on Tuesday, May 2, 2017 1:12 PM
waikong
pm sent thanks
    November 2003
Posted by tempestjohnny on Tuesday, May 2, 2017 1:16 PM
jeaton01
thanks John. I think I'm all set but I'll keep you in mind if needed
Posted by waikong on Thursday, May 4, 2017 2:19 PM
Johny, just sent the scanned instructions via email, please check to see you got them.
