Testors (not Modelmasters) Lt/Dark aircraft gray
    June 2004
Posted by seasick on Friday, May 26, 2017 10:57 PM
Testors makes a light and dark aircraft gray spray paints not in the model masters brand.  Has anyone used these paints? Are they close to any of the FS standard colors?
Chasing the ultimate build.
Posted by Don Stauffer on Saturday, May 27, 2017 9:41 AM
I have used them, but never measured the color- that is a lot of work.  In fact, anyone know of a table of RGB values of FS paints?  The paints work and thin just like the MM paints. I assume the difference is the colors.
One thing I like about the little square bottles- if I do not clean the threads well enough when I replace the cap, I can still take the cap off again.  I made a fork out of 1/8 inch aluminum and screwed it to my workbench.  The opening in the fork is cut to match the width of the bottles. I grab the cap with my pliers and fit the bottle in the fork and then turn.  Even with those rubber jar opening sheets I have ruined a few jars of MM by letting the threads get too dirty.
    June 2004
Posted by seasick on Saturday, May 27, 2017 11:17 PM
I've made an "agreement" that I would use water based paint and not oil based. Its maybe less of an agreement.  I use the Testors flat white a lot, and their dullcote and glosscote. I've acquired some spray cans of the light aircraft gray (three cans) from an estate sale in my neighborhood the cans are a few years old unopened and should work well. If the paint doesn't have a green tint to it I'll use it as light ghost gray. if its closer to gull gray or sea gray I have projects I can use them with. I'm just going to take an old broken model and spray it and see what it looks like.
    June 2004
Posted by seasick on Monday, May 29, 2017 6:03 PM
Red - blue - green is for light. For paint and ink the primary colors are cyan - magenta - yellow.
The "dark aircraft gray" is close to Light Ghost Gray in brightness but with much less blue. The light aircraft gray seems to be closer to camo gray. I'm not a ribbit counter so the cans will be used up soon enough.
