P-82B Merlin Powered Twin Mustang...
    June 2017
Posted by fotofrank on Tuesday, June 13, 2017 8:22 PM
I'd like to build a Merlin powered P-82 as it might have appeared over Japan escorting B-29s, if WWII had lasted through 1946 and into 1947. My plan is to build Monogram's F-82G kit but change the "Allison nose" to a "Merlin nose." I'm trying to figure out how to go about this. The exhaust stacks on the F-82G are these square things that I guess hide the exhaust flame on the night fighter version of the F-82. So I'm wondering, should I get the F-82 kit and two 1/72 scale P-51 kits and do a nose swap? The P-51 and the P-82 are such radically different airplanes that I wonder if such a swap is possible without a lot of surgery. I've thought about just removing the square F-82G exhaust and replacing it with Merlin exhaust from two Mustang kits but the nose swap seems to make more sense. I'm open to any ideas anyone might have. I haven't been back in the hobby long enough to have accumulated a lot of extra unused parts. So that's where I am.
BTW: Have a look at this, it's kind of where my idea comes from:
http://xp-82twinmustangproject.blogspot.com/
OK. In the stash: Way too much to build in one lifetime...
    March 2009
Posted by wolfhammer1 on Tuesday, June 13, 2017 8:32 PM
Depneding on how accurate the kits are, you might be in for quite a bit of work.  As I recall, the F-82 is loosely based on a P-51H, which has different contours than the P-51D.  That could make matching the grafted nose to the rest of the plane involve a lot of putty and sanding.  I'd want to do a bit more research to see how the nose contours vary betweeen the Allison and Merlin engines.  Good luck.
John
    June 2017
Posted by fotofrank on Tuesday, June 13, 2017 8:42 PM
Yeah. Good call, John. I had forgotten about the P-51H factor in the design of the P-82. At least the P-51H was still Merlin powered.
    September 2005
Posted by richs26 on Tuesday, June 13, 2017 8:55 PM
Yes, you do need 2 H models to do the swap as the H used an uprated Merlin.  Bet bet would be an RS Models H as the donor according to Scalemates.
WIP:  Monogram 1/72 B-26 (Snaptite) as 73rd BS B-26, 40-1408, torpedo bomber attempt on Ryujo
Monogram 1/72 B-26 (Snaptite) as 22nd BG B-26, 7-Mile Drome, New Guinea
Minicraft 1/72 B-24D as LB-30, AL-613, "Tough Boy", 28th Composite Group
    June 2017
Posted by fotofrank on Tuesday, June 13, 2017 9:02 PM
I saw the RS Models kit. Twenty bucks for the kit, I think. Injection molded too. I was looking at 1/72 scale P-40 kits too, just for the exhaust stacks.
    June 2017
Posted by fotofrank on Thursday, June 15, 2017 10:18 AM
Well, I've thought about it and slept on it and thought about it some more. I'm going ahead and buy the Monogram/Revell F-82G and build it stock out of the box. I'm not going to modify the exhaust. I know there are a lot of kit bashers out there that will say "no, you hafta do it." I just don't want to spend the money on the two P-51H kits, really. I'll still paint the twin Mustang in WWII colors of some fighter group based on Iwo Jima to get what I'm after. I wanted to build a P-82 that my dad might have seen looking out of the flight engineer's window of his B-29 on the way to the Empire. Of course, the war ended and my dad never went overseas, but what if, you know...
    June 2017
Posted by fotofrank on Friday, June 16, 2017 9:38 AM
I went to Michael's this morning to get some tack stuff and dowells to use for painting canopies. While I was there I found two Monogram F-82G kits and I bought both of them. I was reading up on the Twin Mustang last night and discovered that the F-82G was delivered to the AAF during 1946 so it will still appropriate to paint the airplane kit in WWII Mustang group colors I believe.
    November 2003
Posted by mississippivol on Friday, June 16, 2017 8:56 PM
This is just an idea, but you might consider a scheme from one of the P-47 groups, too. It certainly is in the realm of possibility that those groups would convert to the P-82. It gives you options anyway.
    June 2017
Posted by fotofrank on Saturday, June 17, 2017 6:39 PM
I'll have to look that up. Jug groups never occured to me. I know they were there.
