It's very embarrassing to buy a Monogram 1/48 scale F-105D off eBay, get through 90% of the build and only then realize......
No canopy or gunsight parts.
Would anyone happen to have a spare set?
Yes, I've already checked with Revell and they have no more in stock. ☹️
Don't know if they are interchangable or not, but have the revell 105 Thunderstick version that turned into a paint practice item before completion. If they will work for you, more than welcome to them.
Clear sprue on it's way to you, glad to be able to help out.
Glad you got some help, I have a complete cockpit from the HobbyBoss kit cause I used an Aires resin set. So if that helps let me know.
goldhammer Don't know if they are interchangable or not, but have the revell 105 Thunderstick version that turned into a paint practice item before completion. If they will work for you, more than welcome to them.
Those parts should work. The only difference between the two kits is the additional fairing on the fuselage spine of the Thunderstick II. Otherwise the kits are identical moldings.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
- Plankton
LSM
stikpusher goldhammer Don't know if they are interchangable or not, but have the revell 105 Thunderstick version that turned into a paint practice item before completion. If they will work for you, more than welcome to them. Those parts should work. The only difference between the two kits is the additional fairing on the fuselage spine of the Thunderstick II. Otherwise the kits are identical moldings.
Yup, that is correct, sir! Thanks again, Art!
