Aluminum Foil landing gear piston question
    September 2014
Posted by rooster513 on Saturday, October 7, 2017 12:16 PM
So I've seen a couple people on here use aluminum foil to cover the piston portion of landing gears. I like the clean shiny look this gives but been struggling to get it to stay in place and look clean. Anyone have a process/tips for doing this??
-Andy
    March 2005
Posted by philo426 on Saturday, October 7, 2017 12:22 PM
You might be better off using Bare metal foil or Alclad.
    June 2013
Posted by bvallot on Saturday, October 7, 2017 1:36 PM
Rooster, I've been using a strong white glue to adhere the foil. Nothing too fancy. Just be sure to cut the appropriate width as best you can and only use a small dab so as not to create a mess. The less you fuss with it the better. You shouldn't need a long length of it either. 1cm ought to suffice. Also ensure the surface of the strut is smooth without any raised seams.
That'll do ya! =]
On the bench:
Tamiya F4U-1  Kenneth Walsh
    January 2015
Posted by M. Brindos on Sunday, October 8, 2017 12:22 PM
Most of us are using Bare Metal Foil for such applications. It's super thin and self adhesive.
Its much easier to use than standard kitchen foil.
Unless you're covering an entire model a sheet will last you for years. It's worth the investment.  :)
- Mike Brindos "Lost Boy"
Posted by Don Stauffer on Sunday, October 8, 2017 12:27 PM
I now use a chrome paint.  As long as you use flat aluminum for the strut itself, a good chrome silver gives good contrast.  Also, there are some chrome striping tapes in 1/16 and 1/32 inch.  I have used those- they are self adhesive.  When I used bare metal foil, I just cut it into a strip as long as needed, and the adhesive on the bare metal foil was enough.
For white struts, the chrome silver still works well.  It clearly defines the oleo area.
    November 2008
Posted by plasticjunkie on Sunday, October 8, 2017 12:33 PM
M. Brindos
Im with Mike about the BMF but IMO, not really needed unless the scale is 1/32 or larger.
I generally use chrome paint for such applications and works out very well.
 GIFMaker.org_jy_Ayj_O
    September 2014
Posted by rooster513 on Sunday, October 8, 2017 5:58 PM
Thanks for the advice all! I think I'll look into some chrome paint for future builds.
-Andy
    January 2003
Posted by Darren Roberts on Sunday, October 8, 2017 7:09 PM
I recently discovered a chrome silver paint pen. I got it at my local hobby shop. It is absolutely fantastic. It gives a perfectly smooth chrome finish and comes in varying widths. I use the smallest one. It's also great for chrome trim if you're a car builder.
    September 2014
Posted by rooster513 on Sunday, October 8, 2017 7:47 PM
Darren Roberts
That sounds interesting Darren. What's the brand?
-Andy
    September 2012
Posted by GMorrison on Sunday, October 8, 2017 8:29 PM
One thing about this exercise. Do look at photos of the aircraft on the ground. For some reason some kit companies mold the part in the extended position.
    March 2006
Posted by simpilot34 on Monday, October 9, 2017 1:48 AM
Putting foil on the struts seems like too much fuss to me. A good friend of mine that has won several first place trophies and a best of show, uses apprpriately sized drill bits for his oleos. He cuts out the oleo part and drills out the strut from the bottom into main part of strut deep enough for a good seat, polishes and cuts off drill bit shank and putties the hole at the bottom. Most realistic oleos I have ever seen. They really do have the right shade and look! Just another technique to kick around.
Cheers, Lt. Cmdr. Richie "To be prepared for war, is one of the most effectual means of preserving the peace."-George Washington
    September 2013
Posted by blackdog62 on Monday, October 9, 2017 3:13 PM
my problem is marking a nice seem.
    September 2012
Posted by GMorrison on Monday, October 9, 2017 8:19 PM
Ritchie- wouldn't it rust?
    June 2014
Posted by BrandonK on Tuesday, October 10, 2017 9:53 AM
I use aluminum tape. It's made for heating and cooling ducting in homes and can be found in hardware stores. The role works well as it is thin and adhesive backed and can also be used as the reflector in lamps. I have had my role for a few decades and I have enough to last the rest of my life.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    March 2006
Posted by simpilot34 on Friday, October 13, 2017 7:01 PM
GMorrison
Bondo, the models of his I saw had been in his display case several years and had no signs of rust that I saw. I'm sure a light coat of clear would alleviate any worries though.
    September 2014
Posted by rooster513 on Friday, October 13, 2017 7:53 PM
BrandonK
BK
That's a good idea BK. I may have to give that a shot.
-Andy
    January 2009
Posted by fermis on Friday, October 13, 2017 11:26 PM
Personally, I really like Testors "silver" (1/4oz square jar), as the very last thing I do. I put it on a little heavy, dries nice and shiney! I have used aluminum tape in the past, and it looks great, but you're left with a seam and the adhesive gives way over time. I have also used aluminum rod/tubing with great results (similar to the drill bit idea, mentioned already).
