MODEL MASTER CLEARNER ?
    November 2017
Posted by schooner on Saturday, November 18, 2017 9:00 PM
Hi Guys
I'm fairly new to using ENAMEL PAINT.
First time I'm using it.
Question Please: What do I use to CLEAN my brush with?
Thanks Guys
Schooner Cool
GOD BLESS YOU ALL Angel
    September 2012
Posted by GMorrison on Saturday, November 18, 2017 9:13 PM
This is the one time where most anything called "thinner" is ok. As long as it's petroleum spirits based.
I sometimes use lacquer thinner for a really hard clean, but it can be tough on brushes.
Testors makes a good airbrush thinner that comes in a red metal can. I always use that with Model Master enamels as thinner, and since it's there in the paint area, use it to clean your brushes too.
    October 2005
Posted by CG Bob on Saturday, November 18, 2017 9:15 PM
For enamels use mineral spirits (AKA paint thinner).
    July 2012
Posted by littletimmy on Saturday, November 18, 2017 9:16 PM
Any thinner that says its for Enamel will work.
I have also used: Turpintine, mineral spirits, Laquer thinner , and in a "pinch" Regular Gas.
HOWEVER.... if your brush has a plastic handle, or if the brush hairs are nylon or some sort of synthetic,     Gas and Laquer thinner will melt it.  Also.... An air brush has rubber O rings in it. O rings DONT LIKE GAS !
Didnt know if you meant paint brush or airbrush, so I tried to cover all the bases.
 Dont worry about the thumbprint, paint it Rust , and call it "Battle Damage"
    June 2010
Posted by 5-high on Saturday, November 18, 2017 11:27 PM
Personally I'd never ever use gasoline to clean anything period !!..its bad enough that we use lacquer thinners..enamels use low odor turpentine its safer ..and for those tough cleaning jobs (in your airbrush )..then use lacquer...spraying gasoline through an airbrush is just asking for disaster
    March 2015
Posted by Toshi on Sunday, November 19, 2017 4:53 AM
I utilize exactly what G Morrison uses.  The Testors thinner in the red can.  That works best.  In my current project of which is a Revell B-17G Flying Fortress, I’m using nothing but enamel paints for the first time. I normally use acrylic paints.  My acrylic paints are normally Model Master, Tamiya and Vallejo paints.
Your friend, Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    June 2014
Posted by Tanker - Builder on Sunday, November 19, 2017 6:48 AM
Hi;
 Okay there's always this too . For over fifty years I used and still do for brushes , a good old standby . It's well known name is " Naptha " . You know , Ronson Lighter fuel .
 I was looking for a thinner/cleaner that was gentle on the brushes and cleaned deeply . Well , Naptha fills the bill and it doesn't smell as bad as some things I can think of .T.B.
    June 2017
Posted by Chemteacher on Sunday, November 19, 2017 10:28 AM
For cleaning the airbrush or paint brushes, I’ve been using lacquer thinner from Lowe’s. For thinning paints, I use the same as the paint manufacturer.
On the bench: Revell-USS Arizona; Airfix P-51D in 1/72
    January 2003
Posted by murph on Sunday, November 19, 2017 10:36 AM
Chemteacher
Yup.  Turpentine for airbrush and paint brushes and Model Master Thinner for my MM Enamels and MM Lacquer Thinner for my MM Gloss, Semi and Dull Coats.
Retired and living the dream!
Posted by Don Stauffer on Sunday, November 19, 2017 10:46 AM
There is some really crappy stuff being sold as paint thinner.  The stuff has particles in it that do not dissolve and ruin paint, so I definitely do not use it for thinning paint. I find it even leaves residue in brushes.  It is some sort of synthetic product.  So I do not buy anything that does not say either turpentine or mineral spirits.  Another way to tell the bad stuff is its appearance- it is not perfectly clear, but slightly cloudy like milk thinned with water.  Unfortunately, it is sold in opaque containers, which is why I only rely on the labels now.  While I keep lacquer thinner on hand for airbrush cleaning, I think it is too hard for brushes, and I don't need something that strong, so I only use the enamel thinner (turpentine aka mineral spirits) for brushes.
    November 2017
Posted by schooner on Sunday, November 19, 2017 11:03 AM
Hi Don
Its the new guy, you've helped me out before.
Question Don Please.
Do I always have to thin Model Master Paint with thinners before I apply them to my airplanes?
Or can I use it right out of the bottle?
Thanks Don
GOD BLESS
Schooner Cool
    November 2017
Posted by schooner on Sunday, November 19, 2017 11:23 AM
Hi Tanker- Builder
THANKS 4  you tip on using NAPHTHA on enamel paint brushes.
The first time I'm going to use Model Masters Enamel Paint.
I haven't use the enamel paint yet.
Here's my question, please.
Do I thin the paint FIRST before I use it. Or use it right out of the bottle?
Thanks Guy
GOD BLESS
Schooner Cool
    November 2016
Posted by elation on Sunday, November 19, 2017 12:43 PM
When I was younger, I used Lighter fluid.
Worked well and cheap.
    February 2010
Posted by 68GT on Sunday, November 19, 2017 1:39 PM
In an airbrush I use their Universal Enamel Thinner.  I mix 3 parts flat with 1 part thinner and 3 parts gloss with 2 parts thinner.
For paint brushes you can use laquer or enamel thinner, turpentine, turpenoid or mineral spirits
On Ed's bench, ???
Posted by Don Stauffer on Monday, November 20, 2017 8:33 AM
schooner
Hi Don
Thanks Don
GOD BLESS
For brush painting, I can brush right out of a new bottle fine, without thinning.  But I find the longer total time the bottle is open, the more thinner evaporates and the thicker it gets, needing thinning at some point- you have to play it by ear. It always needs to be thinned for airbrushing.
    June 2014
Posted by Tanker - Builder on Monday, November 20, 2017 8:39 AM
Hi Schooner ;
 I do apologize . I forgot to let you know what mix I use for my airbrush with Model Master  paints . When I do airbrush I cut it 50-50 . But that is for new paint . Old paint is so-so on that .Sometimes you need a 60-40 mix with older paint .
 Now I am talking an unopened bottle more than a year old . Being stored in a garage , paint gets subjected to extreme variations in temperature . This does affect the paint .
