Hi saltydog. I have used Mr. Surfacer, and it is lacquer primer. So that means that it fills pretty well, but you don't want to use it for deep pits and imperfections. In other words, if you have small marks or imperfections in the joint of the fuselage, then you could brush this over that area and it would take care of it fine. It is very soft, so you need to use fine sandpaper as well. If you wanted to, you could airbrush this as well.
One thing to keep in mind it that this product is really soft. So if there was an area, such as a scribed line that needed to be smoothed out and the material should be soft - so that it is easy to sand out. Rather than CA, which is kind of tough, even if you start right away.
I hope this helps out, and if you have any more questions, give me a holler!
best wishes
