Thanks Mike, if you build the Fokker next watch out for the fit of the fuselage around the cockpit framing. I built the WNW Fokker D.VII last year and was frustrated to find that the top of fuselage wouldn't close up behind the cockpit. After discussing this with others I found that I wasn't the only one to have this problem. The top rear corners of B10 and B11 have raised circles with a hole in the middle to accept pins from the top corners of the seat bulkhead. If you deepen the holes in the circles then cut them level with the rest of the fuselage frame the fuselage will close around the cockpit.
modified parts at the top
original parts at the bottom.
