Anyone aware of any cockpit PE, panels and belts and the like, for the ICM 1/48 I-16 Type 24 (48097) kit?
I've built Eduard's version which comes in a Profipack if I recall, but for ICM's new (2016) tooling, I'm not finding much of anything as far as photoetch goes. Their cockpit is quite peculiar as it has a sandwich of clear for IP faces and solid plastic for the IP itself but lacks any decals or otherwise.
Alternatively I might try to just use some Luftwaffe dials from Airscale or something like that.
The only thing i could find for that kit was a set of masks. There is a CMK resin pit and Kuivalainen PE set, both for the Eduard kit, but they might work on yours.
Roll Models has a bunch of I-16 stuff that you could make work in your ICM kit.
WIP: Monogram 1/72 B-26 (Snaptite) as 73rd BS B-26, 40-1408, torpedo bomber attempt on Ryujo
Monogram 1/72 B-26 (Snaptite) as 22nd BG B-26, 7-Mile Drome, New Guinea
Minicraft 1/72 B-24D as LB-30, AL-613, "Tough Boy", 28th Composite Group
Check for what works for the Hobbycraft kits. Mark Buchler used to make update resin parts for them. Here's a link to his websdite, don't know if he can still supply them.
http://www.flightlineengineering.com/
John
To see build logs for my models: http://goldeneramodel.com/mymodels/mymodels.html
Great - thanks for all the replies so far. May see if I can fit the Eduard set.
