It's been a number of years, but I want to say that the interior of one of the fuselage halves was a bit light on the molded details - like the ribs and stringers were molded into one half of the vertical stabilizer, but the other was completely smooth. Pretty sure that was on the port side because that is the "visible" half that was molded in clear.
Up in the nose, the Monogram engineers used a series of long pins to seat the interior sections, so you may want to really study that area before you make a decision on where to make your cuts. If the nose art becomes an issue, you might consider modelling a ship that repeated the art work on the starboard half, or find a ship like the 909 (323 BS, 91 BG) where the artwork is directly below the small line of windows of the nose, rather than under the pilot's window. You may lose a section of the "billboard" recording the number of missions flown, but the nose art and name of the ship are preserved after surgery.
Sorry, no photos or logs. I built the visible version in '92 and the cutaway in '98. Those were commission projects, so I focused more on productivity than recording the build. However, FSM published an article featuring a cut away of the 909 ship which had been fitted with interior lights for display. I recall referring to it several times, particularly for modifying a figure to take up the ball gunner's position. They might still have that on file somewhere on the site, or I may still have that issue laying around. It may be of help, so I'll look around for you.
