Build vids never show or say anything about sealing cockpit work. What do you guys do? Unless you are showing or photographing open canopy, I'm inclined to just hit the cockpit with some Tamiya flat rattle can before glueing it in. Thoughts?
I don't clear coat cockpits. Its not an area that handeled once its fitted and i very rarely need to put decals in pits.
I hear you. But it can still get dusty or faded if left on a shelf open canopy. Plus some folks might want to hit it with semi-gloss to deepen the contrasts, no?
If I use a grunge wash in the pit I will clear it, otherwise I usually don't.
BK
On the bench:
A lot !! And I mean A LOT!!
14 / 5 / 2
If I've used enamel gloss paints for switches, levers, knobs, and weather it up a bit. I give the pit a shot of Dullcoat to knock the gloss down and protect the washes.
Jim
Main WIP:
On the Bench: Artesania Latina (aka) Artists in the Latrine 1/75 Bluenose II
Depending upon any washes I may use in a cockpit, I may hit it with a flat coat to heighten the wash contrast before installation and before I apply any clear to replicate instrument lenses.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
- Plankton
LSM
Oxboy I hear you. But it can still get dusty or faded if left on a shelf open canopy. Plus some folks might want to hit it with semi-gloss to deepen the contrasts, no?
Indeed, but a clear coat is not goingt to stop that. And the pit is less likely to fade than the outside. But there is no harm in giving it a clear coat if you wish.
If I know it is going to be sitting around for quite awhile before I get back to it I put a couple of small dots of poster tack on the bottom of the canopy and let it sit. For planes where I am going to display with cockpit open (two piece canopies, I put a tiny bead of poster tack all around canopy mounting surfaces and mask the hole canopy, then stick it in place while I spray the plane. I have never had any paint get inside, so I assume no dust or other crud would.
