I didn't accomplish my goal of getting her ready for paint by Monday, but progress has been made.
The exhaust. Consists of 4 parts, painted with Mr. Color Steel, burnt metal and silver. First time I've used Mr. Color paints and I like them so far.
The exhaust installed.
Blanking plate for the intakes. Used some strip stock I had lounging around.
The fuselage is together.
The wings are on. Starting to look like an airplane. Getting the wings on was the most difficult part of the build so far. I tried to do a trial fit before installing the main landing gear bay, but I had a step at the left rear like something was preventing it from seating properly. I cut down the bulkhead that the exhaust is attached to, but that didn't solve the problem. I installed the main gear bay and that helped align things, but didn't help with the step. I carved and sanded on the interior of the wing, that helped a little. I just kept messing with it until it snapped into place. Once it was in place, I MEK'd the heck out of it so it would stay there. Probably still need to do a little sanding to get it flush, but I'll worry about that later.
The underside.
I did more work on her today. The canopy is masked and fitted. The splitter plates are installed. I also installed the cover for the missile bay. There was a step where the canopy met the fuselage, but a little sanding made it flush. This wouldn't be a problem for most as the kit is designed to have the canopy in the open position. No pics of today's work. Will post more tomorrow. Even though I've had some problems, once the parts are in position, the fit is excellent. I had to use some tape to pull the wings into position, but once they were glued in place, almost no putty was needed. The nose will need some putty however.
