I am waiting for decals for the Mirage so took thos little kit out to play with.
It will be a simple out the box build, I just added belts to the otherwize bare seat.
Pity about the sidewall detail being to soft to really give a noce look, even using my white pencil to "drybrush" still gives a "feathered" look
IMG_20180703_131155 by Theunis van Vuuren, on Flickr
The IP is quite nice being accetate and PE
IMG_20180703_160659 by Theunis van Vuuren, on Flickr
Sofar the fit is quite nice
IMG_20180703_165159 by Theunis van Vuuren, on Flickr
Theuns
These '50s-era jets are my favorites! I'm a big fan of the Panther but I've only built the great Monogram versions. How does the Trumpeter compare to the Monogram one?I'll be following this build! Can't wait to see your progress on this.
Eric
I can not comment on the Monogram F9 as I have not built one yet :)
echolmberg These '50s-era jets are my favorites! I'm a big fan of the Panther but I've only built the great Monogram versions. How does the Trumpeter compare to the Monogram one?I'll be following this build! Can't wait to see your progress on this. Eric
The fit of the nose section is not great, it is to narrow for the fuselage so I had to cut it open and insert a filler piece.
IMG_20180704_091619 by Theunis van Vuuren, on Flickr
The rest of the fot sofar it looks good.
IMG_20180704_093648 by Theunis van Vuuren, on Flickr
Hi,
I've always liked early jets, including the F9F and F10F. Can't wait to see more
Clever fix on the nose piece. I probably would've used a ton of putty and sanding. I'll file that one for future referance and thanks for that.
Jay Jay Clever fix on the nose piece. I probably would've used a ton of putty and sanding. I'll file that one for future referance and thanks for that.
Yeah, his work looks really good....me, I probably would have just shaved the side edges of the cockpit tub a bit so that it was not too wide for the fuse to go together...
Trumpeter offers the F9F3 and F9F4 and Monogram's kit is an F9F5. The Trumpeter kit has recessed panel lines and Monogram's has raised panel lines. Monogram also offers a photo-recon version. The Monogram kit fits very well and there are no major acuracy issues that I know of. The build looks good so far and thanks for the warning on the nose.
The hassle with reducing the size of the cockpit to bring the middle dection of the noe together leads to the very front nosecone not to fit and this will sand a lot harder around the installed guns :-(
Anyhow no big problem, I now need to re scribe the lost detail.
The wings have been assembled and I decided to drop the flaps on them to give a bit more feel to it. The detail on the wing side rib of te folded wing is basically zero while the fuselage exposed rib has a little detail, I will have to put some work into these areas as I intend to fold the wings.
My build moe joe took a real knock last night.
My panther was basically ready to paint, all primed and sanded. I was clumsy and knocked over the bottle of tamiya thin cement onto the table, no big deal the model was not close to it.
Apon closer look I saw a nice big blotch on the windshield where a single drop must have landed melting a fat ugly spot into the "glass" section next to the framing....not sure it can be rectified :-(
I painted the LE alclad, the gloss blue is much darker than in the pix
IMG_20180731_140147 by Theunis van Vuuren, on Flickr
IMG_20180731_140111 by Theunis van Vuuren, on Flickr
I got the worst of the canopy marks sanded and pollished out to an acceptable limit. Yesterday I started to decal, went on OK....untill I noticed that the nose undercart has broken off and is missing AARRG! the model seems cursed LOL
I will have to scratchbuild something to look like a nose strut.
Here it is before I put a satin clearcoat on.
IMG_20180803_112752 by Theunis van Vuuren, on Flickr
Looking good! Home stretch.
Thanks,
John
Hey Boeta. I know the feeling - I just finished a Hasegawa Avenger that fought with me to the bitter end . It does look good in the cabinet now though. Waiting to see that Panther finished - sterkte!!!
I must say I am glad this model is completed and off the table :-)
IMG_20180929_085955 by Theunis van Vuuren, on Flickr
IMG_20180929_090032 by Theunis van Vuuren, on Flickr
IMG_20180929_090100 by Theunis van Vuuren, on Flickr
IMG_20180929_090125 by Theunis van Vuuren, on Flickr
With the wings up it kinda looks like an Imperial Shuttle ;-)
Glad to see you were finally able to beat this one into submission
Question about the nose, would you have been able to glue the fuselage and nose halves together, or were they opposite? I’ve got a build coming up that I may have the same issue with, just curious.
I’m glad you built it with the wings folded. First thing I thought was “that’s unique!”
Great save .. lovely, clean build!
Of the 1950's navy aircraft the F9F is my favorite.
Hector Berlioz
Thanx
I need to buld naval aircraft with folde wings as I have no more shalf space ! LOL
I think one could try glue the nose sections to the fuse halves first and then join it, I just followed the instruntions and this is the first real issue I had with this kit fit wize. They supply the glazing for the Recon camera nose so that is why the nose is seperate, maybe the original camera nose fits better,I dont know
I was just curious. You handled it expertly once you saw the fit issue.
Sounds like it’s time for more shelves!
More space indeed!
