1:144 scale SH-3G Sea King
    February 2005
Posted by marcopreto on Wednesday, July 11, 2018 8:22 AM
Here are a few photos of the early stages of the model presently at the modeling bench.
It's a kit from Sweet Models, in their typical 1:144 scale. This one will be completed as  Nasa's 735 (nº 149723), one of the options included in the kit.
The kit details are generaly very nice, but the winch is somewhat crude, when compared to the rest. So I decided also de improve some other bits.
The first item to be improved was the tail rotor. The kit provides both the 5 and the 6 bladed options. The detail on the 6 bladed optin is much nicer, but Nasa's 735 used the 5 bladed tail rotor. So I've scratched a rotor hub using brass rod and some pe leftovers. The original kit part can be seen on the right.
Fuselage halves when together almost free of problems (some filler, sanding and that was all).
The exhausts were improved driling them out on an angle and fitting the resulting hole with a brass tube of the apropriate diameter (cut with the same angle as the hole).
I'm also improving the main landing gear, using the kit's wheels (after correcting their circunferance) and building the gear mostly from plastic rod and plastic card.
I hope to post more soon.
Cheers
    April 2015
Posted by Mopar Madness on Wednesday, July 11, 2018 10:03 PM
That’s a lot of sweet detail packed in a 1/144 chopper!  I’m looking forward to seeing the progress.
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
Posted by gregbale on Monday, July 16, 2018 9:40 AM
Great work so far!
Having done a handful of these puppies, I have great respect for your mods to date. As with any Sea King kit, be sure to check window positions and fuel fill points to make sure they match your prototype.
Cheers
Greg
George Lewis:
    February 2005
Posted by marcopreto on Friday, July 20, 2018 4:41 AM
Thank you for calling my attention to these details!
I have a recent blog post detailing the work done to the main landing gear:
https://mpminiatures.wordpress.com/2018/07/14/sh-3g-sea-king-1144-scale-part-1/
Presently I'm opening the fuselage windows and I hope to share the results soon.
Cheers
    March 2015
Posted by Toshi on Friday, July 20, 2018 6:12 AM
That’s some amazing scratch building skills.  It looks fantastic.  Looking forward to the next installment.
Your friend, Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    February 2005
Posted by marcopreto on Monday, July 23, 2018 5:26 AM
Well, I could not get away from the idea of opening the fuselage windows!
They were marked with a pencil and carved out. They were replaced by items cut from 0.5mm clear plastic. I've opened a window that was marked on the fuselage, only to realize that it did not exist on the helicopter I am modelling! It was simply filled with a mixture of ca glue and talcum powder (with a small amount of a pigment, to tint it).
Primer was applied to check for imperfections and cover the clear parts (from inside they will show black color. The radar/sensor on the cockpit front was turned from brass rod.
The winch is also being scratchbuilt (I still need to build the support). The photo shows the comparison between the kit's part and the part I've turned and machined from brass rod. I will make a post (in a couple of weeks, if I manage) on my blog detailing the winch construction.
Cheers
    February 2005
Posted by marcopreto on Wednesday, September 18, 2019 4:25 AM
Here are a few photos of the completed model.
I hope you like it.
Cheers
Posted by gregbale on Friday, September 20, 2019 6:38 AM
Marco, glad to see this one finally made it to the flight line. It looks spectacular!
BTW...I saw on your Wordpress page that you were planning another project with the same kit. I would heartily recommend replacing the kit's rotor blades with scratchbuilt from styrene sheet or strip. It's pretty quick and easy to do...and there's really no way to make the kit ones look any less 'clunky' for the scale. Here's the same kit with thinned-to-(near)-scale blades:
Not meant as a criticism...but I 'forgot' to replace them on the last Sweet build I did, and the difference really shows:
Greg
George Lewis:
    April 2015
Posted by Mopar Madness on Friday, September 20, 2019 7:05 AM
The NASA livery is really nice looking!
Chad
On deck: Who knows!
    February 2005
Posted by marcopreto on Friday, September 20, 2019 8:33 AM
Thank you so much! Indeed, those main rotor blades are probably the bit of the model I like less! Your rotor blade looks much better!
I'm planning on making a Royal Navy Weatland Sea King HAR, in the yellow livery (I think it is very eye katching)!
Thank you again for your suggestion (I will definitly follow it)!
Cheers
    March 2014
Posted by Dave@WhirlybirdModels on Sunday, November 3, 2019 7:11 PM
marcopreto
Cheers
Couple of things, the yellow Sea Kings were RAF not RN Big Smile
Secondly, if you want to do a Westland Seaking in 1/144, I would suggest the AFV Club kit and one of our conversionswould be a better starting point.  Here is are conversion kits
WBA44007 Sea King 202 Sqn. RAF - 70 Years of Life Saving
WBA44008 Sea King 22 Sqn. RAF - 50 Years of Helicopter operations
Cheers Dave@Whirlybird
Tags: 1/144 , Sea King
