Trashable Test Mule
    December 2010
Trashable Test Mule
Posted by 1943Mike on Thursday, July 12, 2018 2:10 PM
While I was waiting for my 2nd kit of the Meng French FT-17 (I ruined the transmission/engine module in my first attempt - long story) I thought I'd slap together a kit I no longer cared about and try some decaling that I'd not done before.
Here are the results of my feeble attempt to measure, cut, and attach lozenge decals to an old Monogram 1/48 Fokker D.VII. I'm certain many of you would have made a decent model from this kit but, alas, I could not. Still, I like the little bugger and will, at least temporarily, put it in my bookcase display shelf along with my 1/48 Nieuport 17.
My little aircraft model suffers from my not being able to arrange the lozenge precisely enough on the wings so as to eliminate the ugly folds, creases, and botched up holes (for the aileron horns on the top and bottom of the upper wing). At that point I just gave up trying very hard to make it presentable. Still, it's grown on me with all its flaws.
The PRO's: I learned a little about cutting large decal sheets to fit a model part.
The BAD: So much flash I just gave up by the time I got to the elevator braces. The parts fit was not stellar and I didn't bother to fill in gaps since I consider it a mule.
I'd tell you to enjoy the pictures but my inclination is to tell you to relax and have a few chuckles at the pictures that follow.
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
    May 2009
Posted by Pawel on Thursday, July 12, 2018 3:06 PM
Hello!
Lookin' good - looks like you can crank out a nice model without really trying. Must be a talent... :-) Many new modellers would dream to make a model like this! Thanks for sharing and have a nice day
Paweł
www.vietnam.net.pl
    December 2010
Posted by 1943Mike on Thursday, July 12, 2018 4:01 PM
Pawel,
Thanks for being so kind to my little beastie.
I hope I will patiently follow through on what I've learned from you and others here on FineScale when I get around to building its much larger brother:
Hector Berlioz
    March 2015
Posted by Toshi on Thursday, July 12, 2018 4:14 PM
What an fantastic job you’ve done.  I especially enjoyed viewing your decal technique, it’s extremely professional! Awesome build of a unique aircraft.
Your friend, Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    December 2010
Posted by 1943Mike on Thursday, July 12, 2018 5:22 PM
Toshi, Thank you my friend.
My decal technique needs a LOT of work to say the least! Fortunately I do have some kits in my stash such as this one that I now feel I can use as test mules and not worry about the outcome. I only hope that I've truly learned something that will remain in my memory banks when next I have the opportunity to try using a sheet of lozenge.
Hector Berlioz
    January 2015
Posted by PFJN on Thursday, July 12, 2018 9:01 PM
Hi,
I think it turned out great (and looks alot better than anything that I have done) Smile
1st Group BuildSP
    December 2010
Posted by 1943Mike on Thursday, July 12, 2018 10:23 PM
PFJN,
Thanks.
Although the faults can be seen in the pictures I posted, I did not post some of the close ups showing other goofs. I've decided to keep it until it has to be trashed in the rotation of giving up space for newer builds.
Hector Berlioz
    June 2017
Posted by Chemteacher on Saturday, July 14, 2018 10:19 AM
Hey, I think that’s a great looking build. Biplanes are tough to do. Great job.
On the bench: Revell-USS Arizona; Airfix P-51D in 1/72
    December 2010
Posted by 1943Mike on Saturday, July 14, 2018 11:28 AM
Thanks Chemteacher.
Hector Berlioz
    March 2005
Posted by philo426 on Saturday, July 14, 2018 12:05 PM
Very nice model!I remember building an Albatros that suggested using carbon paper to trace the lozenge pattern and carefully painting in the colors.As I recall it was a tedious method but the results were quite good!
    December 2010
Posted by 1943Mike on Saturday, July 14, 2018 6:49 PM
Phil,
I'm sure with a careful hand and lots of patience the method you suggested would turn out very well indeed. I just don't have a steady, careful hand and my tank of patience is running on empty Smile. So decal practice is probably going to be my lozenge route for the next aircraft I build that requires it.
Hector Berlioz
    July 2012
Posted by littletimmy on Saturday, July 14, 2018 7:41 PM
It actually doesn't look that bad.
Definetly not the worst I have ever seen .... ( that would be the kit sitting in the box in my pile of doom. Been there for year's .)
 Dont worry about the thumbprint, paint it Rust , and call it "Battle Damage"
    March 2005
Posted by philo426 on Saturday, July 14, 2018 10:11 PM
Key is a steady hand and a good brush!
