Hobby Boss Blohm und Voss Bv141 1/48 DONE
    January 2015
Posted by Aggieman on Sunday, July 15, 2018 5:56 PM
I've completed my sixth build for this Year of the Axis Build.  This is the unusual Blohm & Voss Bv141 in 1/48th by Hobby Boss.
From what I was able to ascertain, the Bv141 never saw combat due to its rather late entry into the war, and I believe I saw a shortage of engines attributable to more pressing need for Focke Wulf fighters as another explanation for its lack of a wartime record.  But despite its ungainly appearance, it reportedly handled well in the air, although I suspect you would not have wanted a rookie pilot taking this thing out for a spin given its unique airborne characteristics.
For this build, I used mostly Model Master acrylics - RLM 02 and RLM 82 over RLM 65. The insignia are Tamiya flat white and Tamiya flat black.  I bought the Montex Mask set for this kit, but everything else is OOB with the exception of a set of custom-made seatbelts (made by applying Tamiya tape over a strip of aluminum foil, then painting those belts Tamiya khaki).
No complaints over the kit.  It goes together easily.  There are not a lot of parts for this one, with everything on 3 sprues plus a clear sprue.  The only slight troublesome area of the build was in attaching the gondola-side landing strut - that piece resisted all of my efforts to align it properly, or at least to match the alignment I had already achieved on the opposite side strut.  I was eventually able to nudge it into an acceptable position.
I built the basic airframe before addressing the few seams that this kit presented me with.  After I handled the seams to my satisfaction (it took three iterations of sand, scrape, prime to get to an acceptable look), I put down a coat of gray Stynlyrez primer, then used Tamiya flat black in pre-shading the panel lines.
I struggled with the paint scheme for this one.  I've reached a near exhaustion point on these German builds with their splinter schemes, but with as few of these that actually flew, there were very few schemes available in online or printed materials that I could find.  The kit suggested the scheme I eventually went with, as well as an all gray (RLM 02) over RLM 65 scheme.  I almost built the all gray version, but just didn't think that would look that good.  As it turns out with the pre-shading, I think the all gray scheme may actually have looked pretty good, but oh well.
Painting was trouble-free.  RLM 65.  Let that set then mask followed by RLM 02.  Let that set then mask again followed by RLM 82.  The pre-shading accounts for most of the weathering I did on this build, although I did use a silver pencil to replicate wear along the path the pilot probably took to access the cockpit, and I streaked some Flory dark dirt wash off selected panels on the underside.  Finally, I used black and gray pastels for the exhaust stains.
For this build, I used 4 decals - the code on the gondola and the swastikas.  The Montex set included the swastikas, but were so small that I could not make out the demarcation lines on the masks between the black portions of the swastikas, and the white outlines.  The kit decals were garbage, however, and I ended up removing them and using some swastikas off an old decal sheet I picked up shortly after I returned to this hobby back in the mid-1990s.
Regarding the Montex canopy masks, I have noticed a trend with these in my last couple of builds using them.  First let me state that I love these masks - they are easy to apply (easier than Eduard masks), and I have yet to see any paint seapage when I have used them.  But I've noticed a lot of adhesive residue left right smack in the middle of clear plastic.  On a bird like this one, such residue simply cannot be left there - it would mar any quality of build because there is so much "glass".  I used denatured alcohol to get rid of this glue residue, but I'm a bit aggravated about having to do that yet again.
Any way, on to build photos.
So next up for me, I'm leaving the Luftwaffe behind and checking in on Regia Aeronautica with a double build - Maachi's Mc.200 Saetta and Mc.202 Folgore.
Posted by jeaton01 on Sunday, July 15, 2018 8:54 PM
Well done, Stephen.
John
    February 2005
Posted by RadMax8 on Sunday, July 15, 2018 11:13 PM
You are a machine!
Build looks great, just the right look for a plane with a small combat record.
I know you’re headed toward Italy next, any plans on a Japanese build soon? I’d love to see what you can accomplish.
    August 2012
Posted by Rambo on Monday, July 16, 2018 12:11 AM
That's a very odd looking bird, that engine placement had to extremely effect the pilots vision. You done a fantastic job on it.
Clint
Posted by keavdog on Monday, July 16, 2018 1:14 AM
Really nice work on an interesting subject
Thanks,
John
    September 2017
Posted by kensar on Monday, July 16, 2018 7:46 AM
A clean looking build of an unusual design.
Anyone know what they were trying to achieve by offsetting the cockpit (which must have increased drag greatly)?
Kensar
    January 2015
Posted by Aggieman on Monday, July 16, 2018 7:56 AM
jeaton01
Well done, Stephen.
Thanks John!
    January 2015
Posted by Aggieman on Monday, July 16, 2018 7:57 AM
Rambo
Thanks Clint!
    January 2015
keavdog
Thanks John!
    January 2015
Posted by Aggieman on Monday, July 16, 2018 7:58 AM
kensar
Thanks!  No clue what they were trying to achieve with this asymmetrical design.
    January 2015
Posted by Aggieman on Monday, July 16, 2018 8:05 AM
RadMax8
You are a machine!
Thanks!  I remain out of work, so between all the job searching, self training within my field, and honey-do lists, I am amazed that I find any time to get to the bench.
I started off this year with a Japanese subject, the Tamiya 1/32 A6M5 Zero.  Here is the link to that thread.
http://cs.finescale.com/fsm/modeling_subjects/f/2/t/178309.aspx
As for how I plan to finish out this year, I expect to do at least one more Luftwaffe aircraft, a Dornier Do 215 B-5, which will follow up my Maachi builds.  From the beginning of the year, I have had my eyes on December 7 as a finishing date for what will be my final builds of the year, the trio of aircraft that attacked Pearl Harbor on that date in 1941 - a Kate, a Val, and a Zero.
I may end up with enough time to complete another build or two in between the Dornier and the Pearl Harbor trio, in which case I have no idea what I'll build.  I have many other Japanese subjects to choose from, as well as many more Luftwaffe subjects.
    June 2014
Posted by BrandonK on Monday, July 16, 2018 9:22 AM
What an unusual pigeon. I agree, well done. The Germans certainly were willing to think outside the box.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
Posted by Bish on Monday, July 16, 2018 9:55 AM
Very nicely done, this has come out great and nice to see one of these. I am looking forward to the Speical Hobby release of this aircraft at some point.
    July 2010
Posted by roony on Monday, July 16, 2018 10:21 AM
All that glass must have made it a "fun" job of masking.  Well done.
    November 2013
Posted by BrynnWryttur on Monday, July 16, 2018 11:52 AM
Wooooooooow! Looks very cool! Good job on your build. The BV 141 is a very impressive aircraft, one of my favorites :D
Prohibeo Mediocritatis
Forbid Mediocrity
    May 2011
Posted by Real G on Monday, July 16, 2018 5:22 PM
The odd layout of the Bv-141 was to provide the crew with the maximum view using only a single engine and to cancel out propeller torque.  All single engine prop aircraft (except those with a contraprop) experience torque in the opposite direction of propeller rotation.  Normally this is compensated by rudder trim.  The offset position of the Bv-141's engine and crew pod were intended to provide this trim.  Apparently, this actually worked out well and the early aircraft were reported to have pleasant flying characteristics.  The Ha-141/Bv-141A aircraft flew with I believe Bramo engines, which were lighter and less powerful than the Bv-141B's BMW-801.  The change in powerplant altered the aircraft's flying characteristics for the worse, as it was carefully designed to balance using the lighter engine.  The heavier prop torque and engine vibration, plus the addition of the asymetrical horizontal stabilizer combined to make for inferior handling.  The RLM were put off with the aircraft's bizarre appearance, so the problems with the pre-production B series were enough for the project to be cancelled.
But I think it was soooo cool.  Cool
“Ya ya ya, unicorn papoi!”
    April 2015
Posted by Mopar Madness on Monday, July 16, 2018 9:47 PM
Nicely weathered! Yes
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
Posted by jeaton01 on Monday, July 16, 2018 11:21 PM
Aggieman
 kensar
Since it was an observation airplane the idea was to not have the engine in front restricting visibility.  But if I was going to attack it I'd come from low on the left!
John
