For very thin lines you hafta get in real close like 1 inch. Think of a reversed funnel shape exiting your air brush. When you get in close you're painting with the "neck " of the funnel and not the wider part which is what you want for thin lines.
The closer you get to the subject the LESS pressure you need so the paint doesn't "blow out" of your wanted spray path. Start with 10PSI and experiment from there + or - 1 or 2 PSI until your thin line performs the way you want it too. with some paints I have used as little as 6PSI in my Badger 105.
