Hasegawa 1/48 P-40E
Hasegawa 1/48 P-40E
Posted by jeaton01 on Thursday, August 16, 2018 12:35 AM
Seems like the only way I could allow enough time for paint to dry on the P-40N was to start another Hasegawa P-40.  I even tried working on the B-26 but after a little painting I had to wait on that one too, so here we go.  It's pretty much exactly like the last one, and after two days all the inserts are in and cleaned up and work has started on the interior.  There was just about the same work on clean up for the inserts but different, plastic even in a Hasegawa kit I guess is not exactly the same as to how things shrink, perhaps.  This has the short tail and the aft cockpit inserts are different, left and right instead of one part in the N kit and that made it easier to get those aligned with no external mismatch, I shifted the mismatch to the center seam.
The box art and instruction color scheme page.  Neither of these schemes excite me.
The parts that are different in the P-40E kit.
When I built the Hasegawa P-40N I was not satisfied with how well the wing trailing edges mated up.  I used a Dremel tool with a barrel sander and this rough sanding stick to remove some material from the inside of the upper trailing edges and the fit was better.
Never mind that worm on the bottom of the chin!   To get a good fit on the upper nose inserts Aves Epoxy Sculpt was placed in the recess as shown and the inserts were pressed in until they were flush with the surrounding surface.  Excess epoxy was removed with a wet finger.  And the worm.
All the fuselage inserts are done here.  Gel superglue was used on the tail joint and thick Testors cement from the black applicator with the steel tube was used for the aft cockpit insert.
For some reason the wing inserts did not fit as well on the ends as on the P-40N kit.  I set the best vertical alignment I could on the bottom because it is easier to work on the upper wing surface without damaging the gun barrel detail.
John
Posted by keavdog on Thursday, August 16, 2018 12:57 AM
P-40s all over!  Wow that Vaught nose is crazy looking!  Googling P-40E schemes there's a couple nice RAF birds.  Those gun inserts look challenging.
Thanks,
John
    August 2013
Posted by Jay Jay on Thursday, August 16, 2018 8:18 AM
Oh cool, another P-40. I 'd like to build every one offered as it is my favorite aircraft. I've built a 1/72 Academy ( very good kit ) A 1/48 Hasegawa (nice detail ) and am now attempting to super detail a 1/32 Trumpeter in AVG livery.
Ty for the detailed info on the build , much valued info.
    February 2005
Posted by RadMax8 on Thursday, August 16, 2018 1:28 PM
I like your technique of pre-puttying the inserts. Not a bad idea!
Since you don’t care for the markings, will you be looking to the aftermarket for some ideas?
Posted by jeaton01 on Thursday, August 16, 2018 5:50 PM
Yeah, I have ordered some already.  Surprisingly there are not a lot of P-40E decals out right now, I found some at RarePlane Detective.
John
Posted by jeaton01 on Friday, August 17, 2018 12:00 AM
In between decals on the P-40N the cockpit was assembled.  The overall zinc chromate green was applied yesterday and the instrument panel had already been painted and decaled so there was just some detail painting to do, PE belts on the seat, and sticking it all together.  I did the instrument panel differently on this one, instead of all decals I detail painted and drybrushed the lower half and put the decals on the top.  I put Future over the decal section, and when that was dry enough I painted around the dial faces with Matte Alclad II Clear.  A person can do a lot more with detailng these cockpits, but I find I seldom ever look there again once the model is done.  I did rub some SNJ aluminum powder into the rudder foot rails.  The only part of the cockpit that gave me any hassle was the tube frame that the seat runs on, it was fiddley to get in place.  I put the left side, back, and floor together, because I wanted the best fit there, and then the seat assembly was installed.  A little was removed from the bottom of the seat frame before upper ends would seat properly.  Putting the seat in before either side panel will likely result in misaligned side panels.  You could also drill out the lower seat frame holes and adjust it that way, not glueing the lower end until the side frames were installed, that might be easiest.  Then again, it might just be me and my kit!
Another thing I did different was the prop retainer. I like the removable prop with the vinyl bushing, the prop will turn however it will not spin freely.  I like to take pictures with the prop blurred, so on this one I reamed out the recess where the vinyl part is enclosed and shortened up the vinyl retainer so it was free fore and aft.  It may be more difficult to installl the prop but by pointing the end of the shaft a little it should work.  We'll see.
John
    June 2016
Posted by Murphy's Law on Friday, August 17, 2018 6:14 AM
Looking really good so far, I am currently doing this same kit in the Edward F. Rector, 76th FS, 23rd FG, China (July 1942). I will post pics once completed hopefully by next week. For what it’s worth I posted this question about about a month ago on here about the recessed area under the back windows. Was informed by the fine folks here that this area was always painted fuselage color and not the interior green. Just wanted to let you know before you got too far. But if you like the look it is now go for it.
Posted by jeaton01 on Friday, August 17, 2018 10:43 AM
Thanks, Murphy.  I will check when I get the decals I plan to use.  I'll look for your photos.
John
Posted by jeaton01 on Tuesday, August 21, 2018 9:15 PM
When I built the Hasegawa P-40N I installed the pylon for the drop tank on the fuselage, then the sway braces, and then I mounted the drop tank to the airplane. That was not easy because the mounting points are very small and were hard to locate to the tank and then the glue joint was very small and fragile.  This time the drop tank pylon has been glued to the tank first, using Tamiya thin followed by thin CA to reinforce the joints.  Then the sway braces will be added, and then the tank mount pylon will be added to the fuselage.  All this as one of the last steps.
Since there will most likely be more Commonwealth P-40’s in my future I made some painting masks for the P-40E, which should work for any short tail D to K version.  I have done masks in the past for the Spitfire and Hurricane.  I have made a pdf of the masks and they can be downloaded from the P-40E build log on my web site, or you can right click and download the jpg here which should print to 1/48 scale.
Tamiya Light Sea Grey was used on the bottom, with Model Master Acryl for the upper Dark Earth, and Tamiya Dark Green RAF (2).  I find the Acryl paints rather fragile but this time it worked OK and sprayed very nicely
John
GAF
    June 2012
Posted by GAF on Tuesday, August 21, 2018 10:24 PM
You've certainly started on a nice collection of P-40s, John!  Good work!
Gary
Posted by jeaton01 on Friday, August 24, 2018 10:32 AM
Another one done.  The markings are for a P-40E-1 flown in the defense of Darwin by RAAF F/L Les Jackson.  Schuftie is Arabic for "have a closer look".  I have made a habit to make two sliding canopy sections, one vacuform for posing with an open cockpit and the other the kit canopy for closed cockpit photos.  The kit canopy seldom rests right in the open position.  The masks required are quite different.  On the Squadron canopy the left and right sides are also different, and there was no upper longitudinal framing at all.  Those masks were made by photographing the canopies, tracing over them in Autocad, and cutting them with a Silhouette Cameo vinyl cutter.  There are always adjustments to be made so paper patterns are printed and tried until everything is happy.  The decals came from the ProModeler P-40E kit and look nice when done but took very careful handling to keep them from breaking up.  A few required touch up.  The bead sight is made of fine music wire, I despaired of ever holding on to the tiny plastic part long enough to clean up the sprue gate remains, and it immediately flung itself into space anyway.  Easier anyway to super glue in the wire and cut it to length when the glue is cured.
John
    February 2005
Posted by RadMax8 on Friday, August 24, 2018 1:22 PM
This bird turned out great! Decals were worth the wait for sure. Best part, I think you started and finished this one in the time since I’ve last touched my Zero!
Hm, better make time tonight.
Thanks for sharing!
Posted by jeaton01 on Friday, August 24, 2018 10:24 PM
Yeah, Radmax, better get at it!
Thanks!
John
    February 2007
Posted by DesertRat on Saturday, August 25, 2018 4:17 AM
Fantastic build, Jeaton. Well done!
Warmest regards,
Roger
    January 2017
Posted by damouav on Saturday, August 25, 2018 6:02 AM
Well done John, a spectacular build you have completed their.
I just bought an Airfix P-40B to add to my collection, but I dont think I can pull off as good of a builds as yours though.
In Progress
1/48 Tamiya P47-D Bubbletop
1/48 Hobby Boss TBF-1C Avenger (on hold)
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
Posted by jeaton01 on Sunday, August 26, 2018 9:00 PM
Thanks, Roger and Damouav.
The Airfix kits of the P-40B are real nice, just take your time and have fun.  And their cheap enough to get two so if things go sour you can make a quick recovery.
John
    December 2010
Posted by 1943Mike on Sunday, August 26, 2018 10:39 PM
Splendid build as we're used to seeing from you!
Where do you put all your completed kits?
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
    November 2003
Posted by tempestjohnny on Monday, August 27, 2018 2:56 AM
Great finish John
    January 2017
Posted by damouav on Monday, August 27, 2018 4:10 AM
Thanks John,
I got it really cheap (1/48 for $18 AUD), should have it in my hot hands by Wednesday. I would have bought two, but it was the last one...
I hope to see more of your builds in the future.
Cheers
Damian
In Progress
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
Posted by jeaton01 on Monday, August 27, 2018 8:37 PM
Thanks, John and Damian.
Mike, here's a picture of my display area from a year or two ago, there's one more display case in another room.
John
    April 2013
Posted by Greatmaker on Tuesday, August 28, 2018 9:27 AM
Fantastic build John and an amazing display area. Looks like you have room to grow.  I'm fast running out of room
    September 2016
Posted by ManCityFan on Tuesday, August 28, 2018 9:31 AM
Hey John, fantastic build, and your display area is awesome.  I am quite jealous of both!
Dwayne or Dman or just D.  All comments are welcome on my builds.
