Just finished the bird cage from Eduard "Weekend Edition".
Hope you like the pics
Beautiful work!
I bet bet it took a weekend or two just for the rigging...
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
- Plankton
LSM
thanks stik.
Yeh you were right. It took me 1 weekend to finish most of the rigging
Wow! That's very impressive
In the queue: 1/48 Beech Staggerwing (RAAF), P38 (RAAF), Vultee Vengeance (RAAF), Spitfire Vb (Malta), Spitfire VIII x2 (RAAF), P39 x2 (RAAF), Martin Baltimore (Malta?), Martin Maryland (Malta), Typhoon NF1b, Hellcat x2 (FAA)
Chris
Wow,
That looks great. I would never have thought it was as small a model as it is, til I saw the last picture
Excellent.
Also, I like the paint scheme a lot.
Hard to believe that someone would actually go up in one of those "Kite's" .
Nice job on the rigging ! ( that would have driven me nut's.)
The cockpit look's good too.
She's a pretty little plane, keep her away from the cat's ..... ( they like rigging too ...)
Dont worry about the thumbprint, paint it Rust , and call it "Battle Damage"
That is very impressive. WHat do you use for rigging material?
Nice results.
Kensar
Beautiful job.
"le plaisir delicieux et toujours nouveau d'une occupation inutile"
Thank you friends.
I used EZ elastic line for all the rigging. I highly recommend this product if do rigging.
cnq I used EZ elastic line for all the rigging. I highly recommend this product if do rigging.
Thanks, that's what I'm already using. Just never saw it in white.
I found a pilot in my spare box so I decided to add to it
Excellent work!
You must have the patience of Job and the perseverence of Sisyphus to have done your rigging.
Hector Berlioz
Actually the rigging was not that bad. I was afraid I would not be able to finish the rigging before started the build but once I started doing it it turned out not as bad as I first thought. Now I'm kind of link doing it :) and can't wait to start my next ww1 bi-plane.
cnq Thank you friends. I used EZ elastic line for all the rigging. I highly recommend this product if do rigging.
which specific ez line did you use?
I bought one of those at an IPMS show last year for $5. What did you use for the rigging? How did you do it? I need instruction before attacking this little gem.
Cheers, LeeTree Remember, Safety Fast!!!
Look at cnq's post just above yours.
Here's one method of using EZLine:
https://www.youtube.com/watch?v=6xzFBkGTu7k
EZLine will deform if CA glue touches it which doesn't matter much if you simply want to cement/glue the end of the line. However, you must be careful not to get CA glue on any other part the thread.
The times I've used EZLine I simply stuck the ends of the line into holes I'd drilled in the wings. Use a tiny dab on a very small implement (like the end of a toothpick) to secure one end of the line. Then cut the line a little shorter than the length needed to reach the second hole and, with tweezers or a scissor clamp (hemostat) hold the other end into the other hole and put a dab of CA on it. Probably in 15 or 20 seconds you can take away the hemostat and let the line come back to a gentle stretch.
Hope this helps.
Just couple more pics with my German D3
