Using Brass Fittings
    June 2009
Posted by Linebacker on Wednesday, November 28, 2018 10:16 AM
Occasionally I run across an article or video in which someone is kitbashing or scratchbuilding and uses what is referred to as "brass fittings."  I know where to find brass rods and tubes but these "brass fittings" are different shapes and quite fiddly with bends and turns and angles and holes machined in them and of a size which lends them to use as parts in model A/C.  Does anyone know where they get these "brass fittings?"
    August 2014
Posted by goldhammer on Wednesday, November 28, 2018 10:30 AM
What you are referring to is known as "photo etch (PE)".  Several compaines make it for all kinds of models, common to armor, ships, aircraft.  Most of the interior a/c PE sheets come pre-painted, there are some out there for exterior detailing as wel as for the engines.  Just depends on which model kit you are building as to availability, most are kit specific, but can usually be made to work with another makers kit of the same subject.
It can be quite a challenge, especially in the smaller scales.  But it does add detail to a lot of builds. Has to be attached with either epoxy or superglue, or another adhesive.  Styrene glue won't work with it.
Search - Eduard, Flyhawk, Tom's Model Works, White Ensign just to name a few.
For me it is a good hair removal tool....Wink
    June 2009
Posted by Linebacker on Thursday, November 29, 2018 11:01 AM
I am well familiar with "photo etch."  Is that where these "brass fittings" come from?  What I've seen are not the flat bendable sheets that PE represents, these are formed tubes in curves and balls with screw holes and such, not like any PE I've seen.
    August 2014
Posted by goldhammer on Thursday, November 29, 2018 11:22 AM
Then I misunderstood.  Haven't run across anything like that, sorry.
    September 2012
Posted by GMorrison on Thursday, November 29, 2018 12:33 PM
It would be helpful if you could provide an example with your question.
Brass fittings are common in model railroading. I’ve been away from that for awhile, almost pre-www. Spent many an hour at the LHS pawing through shoe boxes of the stuff.
Somewhat less common in ship modeling, but popular in larger scale sailboat models.
Model Expo and Blue Jacket are good sources.
AFA aircraft, other than PE I’m really only familiar with hardware on flying models. I have a couple of slope flyer gliders with brass fittings. I guess the advantage is that it’s not hard to drill and tap.
You might look at Tower Hobbies.
    August 2014
Posted by goldhammer on Thursday, November 29, 2018 12:52 PM
Got to thinking...Jewlery and beading findings, maybe.  Bigger crafting stores like Michaels and HL
    September 2006
Posted by the Baron on Thursday, November 29, 2018 1:13 PM
When I hear, "brass fittings", I think of building ship models, especially wooden kits.  Or specialty kits, like large-scale models of artillery pieces.
    June 2017
Posted by fotofrank on Thursday, November 29, 2018 2:03 PM
Linebacker, you might mean this type of item from Master Model:
Brass gun barrels I put on a Hasegawa Bf-109E I'm building. Master Model makes a lot of brass fittings, as it were, for many models. Have a look at their website: http://www.master-model.pl/ The brass pieces aren't too expensive either. $6.50 for the cowl barrels and wing guns. Tiny, but they look great.
OK. In the stash: Way too much to build in one lifetime...
Posted by Don Stauffer on Friday, November 30, 2018 8:47 AM
Venders who cater to model ship builders often offer brass fittings- rail stanchions, portholes, mast rings, etc. Might these be model ship fittings?
    January 2015
Posted by TheMongoose on Friday, November 30, 2018 11:57 AM
Makes me think of the parts used for outfitting Steampunk costumes. Lots of misc. little watch parts, gears, rods, valve parts. just an assundry mix of pieces that came from something that used to work, not necessarily something that you buy outright. Or like the bins of extra parts I have from every plastic model I've built LOL I couldn't go anywhere and easily buy that, it was gained through experience.
Are we getting closer to what you were looking for?
In the pattern: Scale Shipyard's 1/48 Balao Class Sub! leaning out the list...NOT! Ha, added to it again - Viper MkVii, 1/32 THUD & F-15J plus a weekend madness build!
    January 2006
Posted by Paul Budzik on Friday, November 30, 2018 12:16 PM
I routinely fabricate from brass ...
Paul
Paul
    January 2015
Posted by TheMongoose on Friday, November 30, 2018 6:33 PM
Ok Paul I’ll bite lol, where do you get the brass from? But seriously, Is it just flats, rounds, and bar stock you buy and then form?
Posted by Don Stauffer on Saturday, December 1, 2018 6:40 AM
I just remembered there are a couple of model car aftermarket vendors that make brass fittings for things like fuel lines and such.  These are in 1:24/25 scale, and look a lot like that shown in the OP.  Pick up an issue of a model car magazine and peruse the vendor sites.
    September 2017
Posted by kensar on Saturday, December 1, 2018 7:08 AM
Brass, bronze, aluminum, and steel (and maybe titanium) can be obtained from OnLine Metals on the west coast.  I think there is another on line shop located in Tennessee somewhere.  These shops deal in small quantities that hobbyists are interested in, not the 'ton' quantities.  They sell rods, tubes, bars, and sheet.
Kensar
    January 2006
Posted by Paul Budzik on Saturday, December 1, 2018 6:27 PM
It almost always starts out as rod stock ... then I machine it into what I want.  The material is "free turning" brass that I get from a local metal supplier.  I sometimes machine aluminum, but only if I absolutely have to, because it mucks up bits and mills.
Paul
Paul
    March 2015
Posted by JohnnyK on Monday, December 3, 2018 9:55 AM
Are you referring to the blue and red  fittings located at the braided hoses in this photo:
Those fittings are brass fittings that have been painted red and blue. They are available from Detai Master  http://www.detailmaster.com/mm5/merchant.mvc?Screen=CTGY&Category_Code=DM-Fittings-BL. I use them on large scale model cars.
