Airfix 1/72nd SM. 79 Complete
I have had this kit well over 20 years. It was bought with the aim of building it in German markings of a profile i saw in the frist referance book i got in the mid 80's. A number of years ago i found a set of Kora decals for that same aircraft, so no fancy Italian paint scheme on this (thankfully).
Ashide from the decals, i also have an old Eduard PE set which while rather basic, does fill out the spartan pit on the kit. The upper pieces is the pit and rear compartment and the gondola.The radio behind the pit is flat, but as the fuselage wilkl be closed up it won't be an issue, as long as there is somthing visible through the small side windows.
The PE set didn't include seat belts, so i pulled a set from my Lutftwaffe spares box.
I then closed up the fuselage and fitted the wings. There is still more filling to do and clean up the seams, some large gaps around the dorsal hump.
The undercarrage legs have been left movable as Airfix designed them. This way i can fold them away and mask before painting. Once thats done i can add the rear braces and fix them in place.
Quite a bit of filling and clean up to do before i go on.
