Trying to find clamps
    February 2011
Posted by 40kminis on Monday, January 21, 2019 11:01 PM
Been trying to find c-clamps or anything that can secure two plastic parts together. Need a set of varying sizes, 1" and 2".
The only ones I can find are metal and will scar up the plastic pieces.
Anyone have any good recommendations on where I could find some?
    August 2012
Posted by Rambo on Monday, January 21, 2019 11:29 PM
I use bar clamps all mine are Irwin but I think harbor freight sells some cheap ones.
Clint
Posted by Don Stauffer on Tuesday, January 22, 2019 10:50 AM
I also love the harbor freight bar clamps, for the price.  The 6 inch Irwin ones are slightly better, but more expensive unless they are on sale.
    May 2013
Posted by hogfanfs on Tuesday, January 22, 2019 11:11 AM
I found these at Menards:
Clamp
Altough, these may be a too large for what you are looking for.
Also, you can try Micromark
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    June 2017
Posted by fotofrank on Tuesday, January 22, 2019 12:40 PM
Harbor Freight for plastic clamps.
OK. In the stash: Way too much to build in one lifetime...
    September 2006
Posted by the Baron on Tuesday, January 22, 2019 3:29 PM
This is the type of clamp I think those who mentioned Harbor Freight are talking about:
They're nylon, and HF sells them in a tube of a dozen or so, in different sizes.
If you get these, do be aware that the gripping surface might need some help to grip and not let the clamp slip off.  For example, when used to clamp the upper and lower halves of a wing, the clamps have slipped right off from the force of the spring and insufficient friction to the piece.
I've put masking tape on some of mine; others have mentioned gluing bits of sandpaper or other abrasives.
I still use clothespins for most clamping jobs, or rubber bands.
    October 2004
Posted by ikar01 on Tuesday, January 22, 2019 3:38 PM
One thing that I have been using for a very long tine are wooden spring loaded clamps that are used to hang up laundry on a clother line and small -medium metal clamps trhat have rubber coated handles and tips.They are just over 2" long and can hold thing pretty well.  I bought my first ones at Sears but later found them hardware stores.
    March 2008
Posted by Caveman on Tuesday, January 22, 2019 5:37 PM
I would have to also recommend mini bar clamps.  Have not marred anything with them yet.  I got my Irwin clamps at a dollar store.  Another thing that gets a lot of use on my bench are my plastic hemostats.  Not as strong a clamp as the others but do in most situations especially tiny areas that other clamps don't fit into.
Posted by Don Stauffer on Wednesday, January 23, 2019 8:36 AM
the Baron
No, I was talking about bar clamps. I like them because they allow a good adjustment for the pressure.  The spring clamps only have a pressure based on how far they are open.
