Does anyone know about this piece of ground support equipment used with the Blackbirds? A model number, drawings, its function, and any other information would be greatly appreciated.
I've been told it's an "air/water separator," which makes sense as all the pictures I have seen show it operating in damp or humid weather. Air from an air conditioning cart or hangar installation entered the tapered end via a large hose and exited out the other end through a smaller hose that connected to the air receptacle in the SR-71 nose gear well. Here it is being used to prepare the jet to leave Bodø, Norway after an emergency landing. The A/C cooled the cockpit and avionics bays.
This photo shows the A/C cart feeding the unit, which is partially out of the frame at right.
I would like to scratch build a unit for a diorama, but I cannot find any information beyond what I have stated here. An equipment designator, dimensions, drawings and/or more photos would be welcome. I have collected every photo and video screen capture I could find, which aren't much, but I did find the end of the Internet in the process. I also tried to contact the Air Force Historical Research Agency online, but the form failed to transmit. Then I tried doing the same with the Beale AFB Public Affairs office, with the same results. I was able to find an email address and send a message, but I doubt they will reply.
Any Habus out there who can help?
Thanks much.
"You can't have everything--where would you put it?"
