Great looking Huey. Well done.
As far as Flickr is concerned it has changed and I figured out how to make it work again, but it is different than before.
First, find the pic you want in FLickr and when you click on it it will enlarge it with only the zoom feature available. In the lower right corner you will see the download symbol. Click download, then it will give you size options. DON"T download it, but rather, right click the size you want to use and you'll see the option of "copy link address". This is the link you will insert into the forums. I've used it a few time now and it works great. If someone clicks on your pics they will be given the option to download it. Other than that it works like it did before. And BTW, my camera roll works again, but the process is the same as above.
BK
