1/48 Eduard J-35 Draken
    April 2015
Posted by Wolfman_63 on Saturday, July 6, 2019 2:40 PM
The next build is the 1/48 scale of Eduard’s Limited Edition J-35 Draken Swedish Fighter. The J-35 entered service in 1960 and served as an interceptor for many years.  It served in Sweden, Denmark, Finland, and Austria until its final flight in 2005. The scheme I will be doing is the J-35F from the F10 wing based in Angelholm-Barkakra  during 1989 and flown by Cpt. Vincent Ahlin.  The limited edition issued by Eduard includes many photo etch accessories and a few resin parts like the ejection seat, wheels, and various add-ons for the fuselage based on which version you build. The decals allow you to build a version used by each of the countries that flew them.
Starting with the cockpit tub I added the photo etch accessories  and detail painted some areas. There are a few photo etch accessories that go on the port fuselage cockpit wall then the tub was installed and the fuselage was assembled.
Follow along on my blog in the build log section – https://davidsscalemodels.com/build-log/1-48-j-35-draken/
Website:
David's Scale Models - https://www.davidsscalemodels.com
    May 2011
Posted by Real G on Saturday, July 6, 2019 4:25 PM
I love the Draken! It was one of the world’s first aircraft to supercruise (i.e. go supersonic without using afterburner).  A brilliant design and what a lovely shape!  I am looking forward to your build!
Things to watch for include the fit of the intake lips and fairings for the gun, and the odd “pinch” where the tailcone attaches to the fuselage.  The intakes foul on the fuselage halves, so the surfaces where they touch need to be trimmed down.  The gun inserts are a little short, but sanding down the mating surfaces of the upper/lower fuselage halves should allow the fit to come close.  The tailcone fix is harder without the use of filler.
Oh and an odd note on the trailing edges of the real Draken’s wings - they have a vertical face!  Kind of like the stabilators on an X-15.  So don’t try thinning the kit’s trailing edges.  The real deal is basically the upper and lower skins coming together with an inset tapering vertical spacer.  But it would be hard to carve out a tapered recess in the kit parts.
“Ya ya ya, unicorn papoi!”
    April 2015
Posted by Wolfman_63 on Sunday, July 7, 2019 6:54 AM
Thanks for the tips! They are always appreciated.
Which kit are you referring to? I am not sure whos kit Eduard used for their limited edition version. The intakes on my kit required some minor work to fit, But were very close fitting to begin with. The version I am building does not have the gun ports. But the parts that fit on the leading edge fit very well. For the tail cone the mold of the part was slightly unlevel. I was able to lightly sand the mating edge flat to get it to fit without putty. Especially just under the rudder was where the gap was the worst.
For the trailing edge Eduard must have realized the vertical spacers between them and they provided photo etch parts for the wings and tail trailing edges to represent this.
I did most of the fuselage detailing and assembly last night. I have some more details to add to the fuselage and then I can start on the landing gear. I will post pictures later this week. I will take a close up of the trailing edge with the photo etch parts so others can see what we are talking about.
Website:
    September 2011
Posted by Tom Hering on Sunday, July 7, 2019 1:42 PM
The Eduard edition is the Hasegawa kit. I'm a Draken and Viggen fan, and I plan to build the kit myself someday, so I'll be following this. Best wishes for your project!
"A little more persistence, a little more effort, and what seemed hopeless failure may turn to glorious success" - Elbert Hubbard
"Perfect is the enemy of good" - attributed to Voltaire
    May 2011
Posted by Real G on Sunday, July 7, 2019 2:16 PM
For the intakes, the outer walls interfere with the fuselage halves, so they rotate out of alignment.  The vee splitter on the fuselage on the left side also needs to be trimmed so the intake can seat tightly to the fuselage.
If your gun blanking inserts fit with no step, then you are lucky.  All four inserts in my kit were shorter in height compared to the fuselage cutouts.
The tail cone issue is caused by sink marks from the internal bulkhead and I think there is a tooling error where the cone and fuselage do not have the same contour.
Interesting that Eduard caught the trailing edge detail.
Still, it’s a lovely kit.  I hope Hasegawa do a AJ-37 Viggen eventually.  I was not wowed by the Tarangus kit.
    April 2015
Posted by Wolfman_63 on Wednesday, July 10, 2019 4:10 AM
Real G
I had none of the issues you had with the intakes. They fit very well. The only trimming I had to do was a little flash on the bottom half of the fuselage.
For the tail cone there were no sink marks interferring with the mating. I just had the tail cone mating surface was not level especially under the tail. Once sanded it fit very well. Actuallu I have not had to use any putty except a few small spots where the parts were trimmed from the sprue tree.
Website:
    April 2015
Posted by Wolfman_63 on Friday, July 12, 2019 9:05 AM
Moving forward on the  J-35 Draken Swedish Fighter I assembled the fuselage, wings, intakes and tail assemblies and then detailed them with some photo etch accessories. The landing gear has been assembled and detailed with photo etch accessories. All painted then installed into the fuselage with their doors. Finally for the week I added some photo etch details to the fuselage.
See all the details and photos from the start on my blog in the build log section – https://davidsscalemodels.com/build-log/1-48-j-35-draken/
Website:
    September 2011
Posted by Tom Hering on Friday, July 12, 2019 4:47 PM
Looking good.
    April 2015
Posted by Mopar Madness on Friday, July 12, 2019 7:26 PM
I like it!
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    April 2015
Posted by Wolfman_63 on Friday, July 19, 2019 6:54 PM
The weekly update on the J-35 Draken has the build up and detail of the ejection seat. This is all resin and photo etch details. I found some reference photos of the seat and copied the detail as best as I could. After being painted I added some scratch built details then moved on to adding the photo etch details and seat belts. The seat was installed into the cockpit tub and I started painting the aluminum center and the gray bottom. Moving to the top I painted the base coat of the camouflage and the tail. Finally the aluminum leading edges were painted. I also realized the tail required a wire to be added as this detail is not included in the kit.  The aircraft is now ready for decals and weathering.
Check out all the build photos from start to finish in the build log at https://davidsscalemodels.com/build-log/1-48-j-35-draken/
Website:
    April 2015
Posted by Mopar Madness on Friday, July 19, 2019 9:02 PM
Excellent detail on the seat!
Chad
On deck: Who knows!
    April 2015
Posted by Wolfman_63 on Friday, July 26, 2019 5:13 AM
This weekly update has the final assembly of the Draken as well the competed photos. I used the kit decals and they were great. They applied easily and worked well. Next using the photo etch parts I detailed the HUD and installed it. I added the dash gauges that sit on each side of the HUD then I painted the frames of the windscreen and canopy. I gave both pieces a nice polish and installed them. Finally the drop tanks and the landing lights were installed to complete the model. This was a nice build. The fit was very nice and assembly went well. The kit utilizes some nice decals. I really enjoyed this build of this unique aircraft.
The entire build from start to finish can be seen at https://davidsscalemodels.com/build-log/1-48-j-35-draken/
Website:
    July 2010
Posted by roony on Friday, July 26, 2019 10:33 AM
Impressive, most impressive.
