Ki-61
    December 2005
Ki-61
Posted by PTConsultingNHR on Wednesday, September 25, 2019 9:37 AM
Hi,
Is there a 1:72 kit of a Ki-61?
Tim
    July 2011
Posted by MJames70 on Wednesday, September 25, 2019 10:58 AM
Aoshima, Dragon, Hasegawa, RS, Tamiya. Likely others.
    May 2011
Posted by Real G on Wednesday, September 25, 2019 12:05 PM
King of the heap is Tamiya’s, followed by Fine Molds.  Tamiya’s kit is the newest, and I believe was based on direct research on the Ki-61 that was recently restored by Kawasaki in Japan.  IMHO that’s the one to get.
But the Tamiya kit is just one version.  If you want a different mark, Fine Molds and RS should have it.
“Ya ya ya, unicorn papoi!”
    December 2005
Posted by PTConsultingNHR on Wednesday, September 25, 2019 7:24 PM
Thank you to you both.
Marks?  There were different marks?
    May 2011
Posted by Real G on Wednesday, September 25, 2019 7:56 PM
Oh ya.  Short nose, long nose, razorback, fast back, etc.  And don’t forget the radial engined Ki-100, which also had razorback and fastback marks.  I can’t rattle off their designations though; I come up empty handed here.  Others will know more.
    December 2005
Posted by PTConsultingNHR on Thursday, September 26, 2019 9:47 AM
Ah, OK.
Thank you.  I guess I'm looking for the long nosed variant and the razorback one  (I guess) ... the one which resembled a Bf-109 (and I know the Ki-61s were not).
Tim
    May 2011
Posted by Real G on Thursday, September 26, 2019 10:04 AM
This might be the one you are looking for:
https://www.1999.co.jp/eng/10014256
Posted by Gamera on Thursday, September 26, 2019 11:04 AM
Yow, just looked it up on HLJ and as MJames70 noted there's a boatload of kits!
https://hlj.com/search/go?lbc=hobbylink&method=and&p=Q&ts=custom&uid=820921983&w=Ki-61&af=selectscale%3a172scale
As Real G stated the Tamiya kit is probably least trouble to build but the FineMolds kit he posted above should be pretty easy too. Probably the RS kits would be the most work.
    June 2017
Posted by UnwaryPaladin on Thursday, September 26, 2019 12:02 PM
The Hasegawa kit is nice, but very basic. However there is a good selection of aftermarket resin and PE available. You can even model it with the ammo access panels open, using the resin aftermarket upgrades.
    May 2011
Posted by Real G on Thursday, September 26, 2019 12:15 PM
I have the Fine Molds short nose Ki-61-I and it is a decent kit.  You just have to watch the fit of the wing/fuselage and it's all good.
I THINK the Ki-61-II is the long nose variant (due to an uprated engine).  And the razorback Ki-100 with the radial engine is based off that.  The Ki-61-III is the fastback version I think.
    December 2005
Posted by PTConsultingNHR on Friday, September 27, 2019 1:00 PM
That's the one.  Thanks, Guys.
