Work in progress - Tamiya 1/72 Spitfire Mk.1
    September 2019
Posted by Nikola on Tuesday, October 8, 2019 7:09 AM
Hi gents,
This is work in progress on Tamiya's 1/72 scale Spit Mk.1.
I think some of the chipping is not to scale but it is what it is. Will try to fix it somehow if I can, but probably won't bother :)
Also, I think that in some areas I had too much hairspray and when I went over with very thin coats of paint, I suspect that it prematurely made the hairspray coat unstable and started to slightly crack (paint was really thin). Any other ideas? Live and learn! :)
Comments are more than welcome so I have a chance to be safe rather than sorry, haha.
Thanks in advance.
Best,
Nikola
            www.shelfforce.com
    September 2019
Posted by Nikola on Thursday, October 10, 2019 5:25 AM
A few steps down the road - ready for clear coat before decals, washes and further weathering...
            www.shelfforce.com
    September 2019
Posted by Nikola on Thursday, October 10, 2019 4:41 PM
Slightly better photos :)
            www.shelfforce.com
    November 2003
Posted by tempestjohnny on Friday, October 11, 2019 6:15 AM
Looks really good
    June 2017
Posted by UnwaryPaladin on Friday, October 11, 2019 6:41 AM
Looking good! What did you use to mask the camo?
I use a silver pencil and a very soft (4B) lead pencil to suggest wear. Never tried the hairspray method.
    September 2019
Posted by Nikola on Friday, October 11, 2019 9:37 AM
Hi Paladin,
I used Vallejo Liquid Mask since it's a hard edge demarcation and freehanded it with a flat brush, approximately, so it's not that exact but it's close enough :)
As for the hairspray method, this is the fourth time I am using it and it really is a tricky method, at least from my experience, because it's easy to overdo, but so far I like it as it looks very realistic. It depends on the HS thickness, base coat thickness, drying time, etc... I mentioned the other problem with significantly thinned down paint which I encountered. I had luck with my T34 with winter camo since it is a temp camo and a lot of it was chipped off, so the thicker HS layer worked fine. For everything else I would use thinner HS coat, especially at 1/72 scale. That's what I learned from my very limited experience :)
I haven't tried the pencil method and had no luck with sponge chipping, but will be persistant and learn that as well :)
Best,
Nikola
            www.shelfforce.com
    September 2019
Posted by Nikola on Friday, October 11, 2019 9:39 AM
Thanks Tempest,
Will try not to mess it up :)
Regards,
Nikola
            www.shelfforce.com
    September 2019
Posted by Nikola on Tuesday, October 22, 2019 5:10 AM
Decals on and weathering continued... :)
            www.shelfforce.com
    September 2019
Posted by Nikola on Tuesday, October 29, 2019 4:11 AM
Hi Gents,
Almost finished. Waiting for the Uschi rigging line to arrive and then on for some better photographs (apologies for the current photo quality as my phone camera sucks). :)
I messed up the canopy somehow, as it fogged from the inside even though I didn't use CA glue. Also, I deliberately left a micro gap between the front windscreen and the movable part of the canopy. Any ideas why it might have happened? I am not happy with the canopy in general. I left the masking liquid on for too long and it was a disaster while removing it. Still needs a touch up.
As for the camo, I think that it should have more contrast between the green and the brown, although it is very much dependent on lighting conditions. I used Vallejo BS Dark Earth and Dark Green, and probably overfiltered the camo scheme and lost some of the contrast, so lesson learned here. :)
Thanks for looking!
Best,
Nikola
            www.shelfforce.com
    April 2015
Posted by Mopar Madness on Tuesday, October 29, 2019 11:14 AM
Oh wow, that's a beautiful finish on that bird.
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    September 2019
Posted by Nikola on Tuesday, October 29, 2019 2:01 PM
Hi Mopar,
Thank you very much. Glad you like it. :)
If only I hadn't messed up the canopy. Crying
Best,
Nikola
            www.shelfforce.com
    April 2015
Posted by Mopar Madness on Tuesday, October 29, 2019 7:29 PM
Unless you know to look for it, you really can't tell by looking at the pictures. I wonder what caused that to happen.
Chad
On deck: Who knows!
