Air Compressor Air Dryer
Posted by Anonymous on Wednesday, March 26, 2003 11:56 PM
Hello All, got a question for you. I am using a small Badger air compressor and I am having a real time with moisture in the line coming out when I spray. Our humidity is around 28% daily and I have two air dryers/filters installed. (Yes the direction is correct!!!) The traps seem to be a little damp, but water is still coming out of the airbrush, all at the wrong time. I can't afford a nitrogen/Co2 tank so I am kind of in a bad spot. Trying to get ready for TamiyaCon '03. This is the filter I have (2). "Amflo 3000E-RET Mini Air Filter". Any ideas??
Thanks in advance.........
Floridapilot1
Posted by BlackWolf3945 on Thursday, March 27, 2003 8:33 AM
FL Pilot,
May I ask how long you usually spend actually painting? When you spray, is it for a few minutes, a half-hour, an hour? That sometimes can have a bit to do with condensation.
Fade to Black...
Posted by Anonymous on Thursday, March 27, 2003 9:25 AM
It does sound like a time issue, Blackwolfscd may have the correct point.
Posted by Anonymous on Thursday, March 27, 2003 10:44 AM
The problem is probably hot air, not time spent painting. If your compressor is runnning while you paint the air it is producing is hot and will not release its moisture into a moisture trap until it cools. I run a small auto shop and we have air lines plumbed into several spots in the shop. At each air outlet we have a water seperator, the air at the outlet has traveled away from the compressor and has had time to cool, thus seperating the water out more easily at the outlet. If the water seperator was attached to the compressor it would hardly collect any moisture because the air leaving the compressor is hot; after this air cooled, water would then puddle in the lines after the seperator.
I can pobably help you engineer a more effective way of seperating water from your compressor; you should never need two moisture traps, not even if you live in Florida. E-mail me and we can discuss your present set up and maybe figure out something better.
N.
Posted by Anonymous on Thursday, March 27, 2003 1:26 PM
There was an article in a magazine recently (I think Scale Auto), where they talked about this very issue (ie. hot air not releasing all of the moisture until it cools). The solution shown was to use a long hose coiled several times in a bucket of cold water. When the air runs through this 'coil' of hose, it cools it like a radiator and the moisture will condense. Then, with a moisture trap at the end of the line, you should have good, cool, dry air for painting.
Check on the Scale Auto site to see if the article is still there.
M.
Posted by Anonymous on Thursday, March 27, 2003 1:37 PM
You didn't mention if you use a tank, if not you might want to add one. It would give the air time to cool.
