First model in 20 years, 100% hand painted
    February 2020
Posted by MB13 on Wednesday, February 5, 2020 7:38 PM
Hi guys, so I'm back in the hobby after about 20 years, unbelievable how the hobby have changed in those years can't believe it! There is an air force base near where I live so I see F/A-18 almost every day so I decided to go with the Revell 1/48 F-18 to start it off. I did not want to wheter it too mutch as I think the ''too pronunced panel wash'' makes it kind of cartoonish and unrealistic, so went with another technique. I also don't own an airbrush so I did the best I could with what I saw on the net and here is the result, nowhere near the ones I did back in the days but still not as perfect as I would have liked so I have some questions:
1- What technique do you use to hand brush your models (For those who still do it lol) Primer or no primer, thin the paint a lot or not that much, what brush to use.. etc
2- Do you have some tricks or anything else that helps for filling, sanding, wheathering etc..
3- I'm hopened to criticism so any tips or advice or anything on everything that could help would be much appreciated!!
Thanks!!!!
Posted by Don Stauffer on Thursday, February 6, 2020 10:26 AM
The only models I had paint are WW1 aircraft (smaller scale), and old ships.  The big problem is brush marks.  WW1 aircraft were hand painted, and no one worried about quality of the finish.  Flat paint does not show brushmarks as much as gloss paint.
The secret of good brush paint jobs are proper thinning ratio, and practice, practice and....
An intermediate step is the use of spray cans for larger surfaces where brush marks are more noticable.
    October 2018
Posted by arbit on Thursday, February 6, 2020 11:44 AM
I had the same reaction when I got back into modelling. The quality of the tools and paints makes the hobby easier. Very nice hand brush work. I've got zoomed in on my widescreen TV and it looks great. Very interested to know what quality you used to get 20 years ago with the hand painting.
    September 2006
Posted by the Baron on Thursday, February 6, 2020 11:51 AM
The secret to painting a model by hand is to thin the paint as much as you can.  I learned this while painting figures, and saw the technique in action looking at Maschinen Krieger and other sci-fi builds, hand-painted using lacquers.  Very thin coats.  If you think about it, that's how you paint with an airbrush, too-you apply thin coats.
Everything else is the same, from prepping the kit for assembly (cleaning the sprues to remove grease and oil), to priming it (priming helps your color coats adhere), and eventually sealing it.
As you've seen in your own build, you can get a really great finish, applying the color coats by hand.
And as with anything else-practice, practice, practice!
    September 2012
Posted by GMorrison on Thursday, February 6, 2020 12:17 PM
Use a flat brush. Thin way down. Don't assume that brush marks will ever level themselves. Try different paints. There's a huge range of "brushability".
    May 2006
Posted by ggatt_2 on Thursday, February 6, 2020 1:55 PM
That is a very nice first effort and I like your decision to display the model in flight. Planes look best when they’re doing what they were designed to do: fly. I echo all of the above regarding brush painting. Although Model Master Acryl doesn’t get much love on various modeling forums I’ve had excellent results brush painting with it and have never had a problem with brush marks. Using a primer is key and I like Tamiya fine white. I thin the paint just a little (it’s already pretty thin) and always apply 2 coats, never going back over a painted area until it’s completely dry.
-Greg
    February 2020
Posted by MB13 on Thursday, February 6, 2020 6:50 PM
Thanks a lot guys for the tips and yes I will practice and practice to try and achieve even better results! My next one is the Hasegawa F-22 and is already on the bench, I hope I will be able to do the camo as real as possible but sure will be a huge challenge!!
Posted by Tojo72 on Thursday, February 6, 2020 7:08 PM
MB13
Its a pretty complicated kit,but well engineered,goes together great.I really enjoyed it.Have fun.
    February 2020
Posted by MB13 on Thursday, February 6, 2020 7:24 PM
Good to know it is well engineered because it is pretty intimidating when you open the box loll.. So far so good the cockpit is beginning to take shape!! Smile
    April 2015
Posted by Mopar Madness on Thursday, February 6, 2020 8:24 PM
Wow, that's very impressive!
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    August 2014
Posted by goldhammer on Thursday, February 6, 2020 9:30 PM
Nice job after the long layoff.
For filling seams I like Perfect Plastic Putty.  Can take off excess with a water dampened Qtip , even after it dries, with no loss of detail.  If you have to sand, it works easier than most of the other putties out there.
    February 2020
Posted by MB13 on Thursday, February 6, 2020 9:41 PM
goldhammer
Thanks mate!
I just bought Vallejo's putty wich can also be taken off with a moistened q-tip. I will try it on my next model should be better than Tamiya's wich I didn't like much. Also bought mr.surfacer 1000 for the very small seams.
    February 2020
Posted by MB13 on Thursday, February 6, 2020 9:42 PM
Mopar Madness
Thank you very much!! :)
    February 2020
Posted by MB13 on Thursday, February 6, 2020 9:56 PM
arbit
Sorry if my words sounded like the results where better 20 years ago but man my models where horrible back in those days loll this one is better by a mile thats for sure!
