F-16 ,on the Tarmac
F-16 ,on the Tarmac
Posted by Tojo72 on Friday, June 19, 2020 5:56 PM
An F-16 at rest on the tarmac would the wing flaps remain up or would they hang down.Tamiya provides both.Surprisingly couldn't tell from google pics.
    August 2015
Posted by crown r n7 on Friday, June 19, 2020 7:03 PM
Good question  the f-16 is a Electric jet I don't think there's any Sag . I would say they stay up,
 Nick.
    November 2003
Posted by mississippivol on Friday, June 19, 2020 8:53 PM
I went with down, but then, I just liked the look.
    May 2011
Posted by Real G on Friday, June 19, 2020 9:01 PM
I had read that when the F-16 taxied, the flight computer angled the leading edge flaps slightly up!  Don’t know if there was a software patch for that.
“Ya ya ya, unicorn papoi!”
Posted by jeaton01 on Friday, June 19, 2020 9:15 PM
I have a lot of F-16 pictures and I would say most parked F-16's in those have symmetrical positions and are often a little lower than faired with the wing, sometimes down more than that but not often.  It would be nice to hear from a ground crew guy.
John
    July 2004
Posted by stikpusher on Friday, June 19, 2020 10:07 PM
Tojo72
This one armed on the alert pad looks to have a slight droop
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    April 2020
Posted by Eaglecash867 on Saturday, June 20, 2020 7:18 AM
The TEFs are 20 degrees down at speeds below 240 knots and/or the landing gear switch is set for gear down, so they sit 20 degrees down when its parked. They're only fully retracted at 370 knots or above, and at varying angles based on airspeed between 240 and 370.  Cool
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
Posted by Tojo72 on Saturday, June 20, 2020 8:21 AM
Thank you everybody,so down is correct,and it looks cool.
    August 2005
Posted by Phil_H on Saturday, June 20, 2020 8:39 AM
stikpusher
Interestingly,  the speed brakes appear to be partially open too.
    May 2006
Posted by Shipwreck on Saturday, June 20, 2020 12:11 PM
Eaglecash867
So, is this ,20 degrees, how we should model it?
On the Bench:
Revell 1/96 USS Constitution - rigging
Revell 1/48 B-1B Lancer Prep and research
Trumpeter 1/350 USS Hornet CV-8 Prep and research
    April 2020
Posted by Eaglecash867 on Saturday, June 20, 2020 12:31 PM
Shipwreck
Eaglecash867
If you want to be accurate, yes.  20 degrees is the maximum downward deflection of the TEFs.  Since the TEFs also act as ailerons, they also have a maximum upward deflection of 23 degrees, but you'd never see that on a parked, cold Viper.
    March 2015
Posted by JohnnyK on Saturday, June 20, 2020 12:42 PM
Here is a picture of a parked F-16.
Go here for more than 150 highly detailed pictures of the F-16. Best website of an F-16 ever.
https://designer.home.xs4all.nl/aircraft/af-16/af16-1.htm
    January 2020
Posted by wpwar11 on Saturday, June 20, 2020 1:03 PM
Man those are cool looking jets.  I gotta get to building mine.
    March 2015
Posted by JohnnyK on Saturday, June 20, 2020 3:16 PM
Every aircraft that I have built in the last four years have been finished in Bare Metal Foil. After looking at these photos I think that I am going to buy an F-16 and drag out the paint machine.
    January 2017
Posted by mawright20 on Saturday, June 20, 2020 4:31 PM
I was one of those ground crew guys, a crew chief early in my career. Whenever the aircraft has been sitting a while after flight, the hydraulic fluid pressure begins to bleed off. The flaperons will then say down and the horizontal stabilizer will tilt into the angled position shown in one of the later response photos.
For an idea of how far down the flaperons droop, I’m 5’10”. At the lowest point these will droop to just above eye level (don’t ask me how I know this...)
    May 2018
Posted by Moon_dk on Wednesday, June 24, 2020 7:49 AM
Real G
That is correct. at ground speeds below 145 knots ... ish the LEF is 2 degrees up (i must admit it's been a while since i did my type rating, so i can't remember the exact speed) This is to prevent premature takeoff, which happened during one of the high speed ground runs of the prototype.
Regarding the TEF, or more corectly the Flaperons as they are both  flaps and ailerons, they will typically sit at a symetrical down angle on the tarmac. But you can easily push them up to neutral with your hands, or at least i could on our "good old" Block 10 and 15's in the RDAF, but given that they were pushed up by hand they would slowly drop down again.
Speed brakes can creep to, but just like the flaperons they are quite easy to push open or closed with your hands ... just don't put your fingers in them when hydraulic pressure is applied.
