B-52 Decals
    June 2009
B-52 Decals
Posted by jimbot58 on Thursday, July 2, 2020 1:15 AM
Hello!
I have been away for sometime but it seems my old profile is still here.
I need to find a solution to a problem with my B-52 Monogram "Big, Bold and Beautiful" 1/72 kit, in particular the decals!
I have had the kit for maybe 20 or more years (perhaps closer to 30+??) and had partially assembled it way back when. I recently decided I was going to take it up again. I have spent weeks painting and assembling it according to the instructions for a Vietnam era plane as pictured on the box.
Problems arose as I tried to use the kit supplied decals and was very unhappy to find they are very thick and and no amount of Microsol could get them to settle down over the raised panel lines and then they silvered badly, even over my gloss finish.
I then reverted to a set of Microscale decals I picked up also many years ago and found them unusable. The first one would not release from the backing paper and then it just disolved into pieces. I overcoated the sheet with multiple layers of decal film to hold it together but still, they will not release from the backing. Soaking one for almost 15 minutes seem to get one to come loose, but when appled to the kit, it would not stick and actually began to crack apart before my eyes. Then it began to lift and curl off the surface into pieces where ever the cracks were.
I have a Warbirds set that gives me the wing markings including the national insignia, but it is for a "G" version and lacks any sort of tail markings appropriate for the "D".
I am at a loss on how to complete this project....
On my workbench now:
It's all about classic cars now!
Why can't I find the "Any" key on my keyboard?
    June 2009
Posted by jimbot58 on Thursday, July 2, 2020 1:18 AM
Did I mention the trouble I had trying to find some usable SAC bomber Green and Tan? I finally located some Testors rattle cans and was able to decant the paint needed.
    September 2012
Posted by GMorrison on Thursday, July 2, 2020 7:20 AM
Is there any way you can scan what's left and print new ones?
    October 2004
Posted by ikar01 on Thursday, July 2, 2020 7:57 AM
Where are you located?
I'll have to consult my 1-1-4 to get the right size national insignias and I have a partial sheet of red numbers.  I can't guarantee the font will be right though.  I may have a S.A.C. shield too.  I checked my photos I took during the war and on the ones showing the right side there were no unit insignia dispoayed, only the three digit number on the nose.  Unlike the tankers, only what was absolute necessary was applied.  You will have to paint the red no walk lines of the wings and fuselage and tail but the kit has those laid out already, just a matter of masking.
    September 2012
Posted by GMorrison on Thursday, July 2, 2020 12:35 PM
Another way is to paint the red first, them mask with the correct width pinstripe tape.
Nice project good to see it come together.
Bill
    August 2014
Posted by goldhammer on Thursday, July 2, 2020 1:25 PM
Might dig back into " in the buff" group build.  Maybe one of the guys there has some help or ideas.
PM or email a couple of them.
    October 2004
Posted by ikar01 on Thursday, July 2, 2020 1:42 PM
I was just looking at some of the shots I took back then.  I didn't see any walk stripes on the 52s.  Nowhere on the tail or the wings and fuselage that I could see.  The tail would particularlly stand out with a red againts black and being so tall.  For the angles I have on the  wings and fuselage I didn't see anything.  It's possible that when they went in for a wash and paint job they just didn't bother taking all the time needed to put those long lines back on.
    June 2009
Posted by jimbot58 on Thursday, July 2, 2020 6:55 PM
GMorrison
I hadn't thought of this approach as I had never attempted this before. I am goint to scan them and then copy. I know I have seen the decal paper or perhaps it was a kit? at my local Hobby Lobby store.
Posted by jeaton01 on Thursday, July 2, 2020 8:44 PM
Here are some high resolution scans of the decals from the 85-5709 kit.  One is normal and the other is very dark to highlight the two white lines on the decal.
Right click and download them.
John
    June 2009
Posted by jimbot58 on Friday, July 3, 2020 9:33 AM
Thank you all for the the input and thank you John, for the scans. I'm going to head over to HL as soon as they open (in an hour) as I seem to be up very early today. I can give this all a try as at this point, as I just want to complete this behemoth and 100% historical accuracy is not going to be huge thing here for me. I just want it to appear authentic and interesting - and done!
It is an interesting build as the size is so large that I have to work on the parts seperately! It's as if I am trying to complete a half-dozen kits all at the same time!
Once assembled comes the next big problem - what the heck am I going to do with this thing? LOL! I will let you all know how it goes.
Thanks
    September 2012
Posted by GMorrison on Friday, July 3, 2020 10:12 AM
John's first scan you'll want to print on clear paper. His second scan would be printed on white paper just for the mouth and nat. insignias.
Or you might paint the white parts and put a clear decal on top.
Be sure to pick paper compatible with your printer- inkjet or laser print.
You'll need a fix- I like Testor's decal bonder in a little spray can.
What I do is print the art on 8 1/2 x 11 that you run through the manual feed.
Then cut out a piece of decal paper the size of the decal sheet and tape it over the image on the paper print, putting tape along the leading edge only.
Run it through the manual feed again.
Let it dry for at least two or three days.
Spray bonder on it.
Let that dry for two or three days as well. I usually find one coat works.
You've created one big decal at this point, so trim each marking out as closely as you can to the image.
It will take a little experimenting to get the right paper type selected, the printing quality setting etc. but once you do write it down.
Bill
    June 2009
Posted by jimbot58 on Friday, July 3, 2020 5:04 PM
Trying to remember how to post a photo.....
I don't remember how I did the photos before, but if you click the little "thingy" above, you will see the decal I am trying to save. I had a Photobucket account but I refused to pay a monthly fee to keep it.
Got the Testors decal paper and after an afternoon of experimentation with scans, and photo editing, got a decent rendering of the large winged 2 on the tail. I also found a sheet of red numbers of various sizes so maybe I can toss some numbers on it and call it good.
The decal I made is out in the shed drying as I have a swamp cooler and it is always too damp in here for things to dry
