Brengun 1/48 Me. P1103
Wiz
    June 2010
Posted by Wiz on Monday, August 17, 2020 12:32 PM
Having never built a Brengun kit before I though I would give this little guy a try. It is a cool little rocket powered fighter that was designed to be a contender in the Light Weight Fighter program that gave the Natter eventually won.
The kit comes on one sprue save for the clear canopy. The low parts count belies the fact that this is a limited run type kit with no locating features and butt joins. Still, it is well molded with nice surface detail.
I also got the photo etch set designed for the kit by Brengun as well thinking it would add some extra details.
The cockpit is a bit of a challenge to get alighned correctly, and the instrument panel interferes with teh control stick, or vice versa, either way I scratched up a new stick.
Once the cockpit was fit, a fit check was done to make sure everything else would fit as it should.
After this the cockpit was detailed, painted and the major pieces were stuck together.
"you better hang on if you're taggin' along"
    October 2019
Posted by Tanker-Builder on Monday, August 17, 2020 12:54 PM
Hmmm;
 Totally Weird, But neat anyway!
Wiz
    June 2010
Posted by Wiz on Tuesday, August 18, 2020 9:11 AM
A couple pics of the cockpit
Instrument panel with the photo etch and film instruments and wireing added to the back of the panel.
And a small base for the finished build. Epoxy putty was rolled out and a can lid of the correct diameter was used to cut a circle out of the epoxy putty. The lines in the hardstand section were scribed in and  the concrete and eart areas painted. The earth area has since been covered with atatic grass.
    May 2011
Posted by Real G on Tuesday, August 18, 2020 1:17 PM
I love "NapkinWaffe" designs!  Did this one get towed into the air via a Bf-109 or something?  Is the armament a single 30mm cannon under the nose?  The pilot would have had to have some serious courage to swoop down on a box formation of B-17s!
“Ya ya ya, unicorn papoi!”
Wiz
    June 2010
Posted by Wiz on Tuesday, August 18, 2020 6:13 PM
Yes, 30mm under the nose. These were to be towed into the air and in the general direction of the approaching enemy aircraft by Me-262's using a "towbar" type arrangement. While maybe not fun, it seems it would be guaranteed to be exciting Indifferent
    May 2011
Posted by Real G on Tuesday, August 18, 2020 9:24 PM
Oh OK.  I have seen drawings of Me-262s with tow bars and bombs with lashed on wings.  Might make an interesting display.
Wiz
    June 2010
Posted by Wiz on Saturday, August 29, 2020 10:47 AM
And finished! Xtracolor paints for the main colors with pollyscale RLM23 for the fuselage band.
