rivetting tools
    August 2020
rivetting tools
Posted by Dodgy on Saturday, August 22, 2020 8:05 PM
Hi peoples, I need some advice. Whilst aircraft are not my main modelling subject i still like to build them and have a number in the stash. As I said in my new member intro, I have come back to the hobby after a lapse of some years and some of the new tools and products can be confusing. I was looking to buy a rivetting tool the other day and was confused by the choices. I build mostly in 1/48th, but also have kits in 1/72, 1/32 and 1/24th. When considering the tools on offer some were specific to a scale, others claimed to be okay for two scales, eg, 1/72 and 1/48, or 1/48 and 1/32. Some advertised twin rollers??. The price range was also staggering. Can someone please offer a poor old Aussie modeller from the age of dinosaurs some enlightenment on this troubling subject?
I long to live in a world where chickens can cross the road without having their motives questioned
    August 2014
Posted by goldhammer on Sunday, August 23, 2020 1:41 AM
As you probably saw, most are a toothed wheel set in a handle.  Spacing of the teeth will be closer for 1/72 than for 1/48.
Suspect that the double ones have a wheel at each end with different tooth spacing for two different scales.
Some folks use a needle set in a small piece of wood dowel or an appropriate size tiny drill bit to make rivet indentations one at a time, but that can get tedious.
I'm in the U.S. and got mine from Micro Mark, but that may not be an option.  Another item to look for would be a "pounce" wheel, used to punch small holes in a paper pattern then gone over with a chalk bag to transfer the pattern.  Should be available at fabric stores.
    April 2010
Posted by Theuns on Sunday, August 23, 2020 6:06 AM
I use the trumpeter rivet tool, comes with 4 different sized wheels and works very well. Loads cheaper than some other ones.
Theuns
    February 2017
Posted by Tubosteve on Sunday, August 23, 2020 4:51 PM
I use the rivet tool from Revell, cost be 8 pounds. Comes with 4 size/scale wheels.
Stay safe........Steve
Currently on the bench: On the bench: Airfix 1:24 Spitfire Mk IXc (17001) as Silver Spitfire G-IRTY, Revell 1:48 Bristol Beaufighter TF.X (03943)
Finished 2024: Tamiya 1:24 Ford Mustang GT4 (24354)
    August 2020
Posted by Dodgy on Sunday, August 23, 2020 4:59 PM
Thanks Steve, it sounds like thats exactly what I need.
    April 2010
Posted by Theuns on Sunday, August 23, 2020 11:35 PM
The trumpeter one I have must be a copy of the revel one as they look exavtly the same.
Theuns
    August 2020
Posted by Dodgy on Monday, August 24, 2020 2:40 AM
Thanks Theuns. Given Revell's status at the moment I might have better luck sourcing a Trumpeter product.
    August 2020
Posted by Dodgy on Monday, August 24, 2020 2:42 AM
Thanks Goldhammer.
    November 2008
Posted by plasticjunkie on Tuesday, August 25, 2020 10:23 PM
I have an RB Productions riveter that attaches to the exacto handle and brings several wheel in different sizes. It's a great little tool to have.
 GIFMaker.org_jy_Ayj_O
