Masking canopy
    October 2016
Masking canopy
Posted by Mrchntmarine on Saturday, October 10, 2020 9:47 AM
So I've read that some like to paint the bottom edges of the canopy black for more detail. I would think you'd paint them whatever color the framing is??  But in my case it's black as that what color the aircraft is going to be. So if I do it, and I'm thinking in dipping the canopies in PFC, woild I paint the edges 1st, then dip in PFC then tape and paint the rest?  I'm using Tamiya and Vallejo acrylic. What you be the correct order of operations?
Keep on modeling!
All the best,
William
    February 2017
Posted by Tubosteve on Saturday, October 10, 2020 9:58 AM
Personally, I use Tamiya paints. I always polish the canopy first with 12,000 Micromesh and then dip in Future, then allow a good 48 hours to dry before masking and painting. Never had any issues that way.
Stay safe........Steve
Currently on the bench: On the bench: Airfix 1:24 Spitfire Mk IXc (17001) as Silver Spitfire G-IRTY, Revell 1:48 Bristol Beaufighter TF.X (03943)
Finished 2024: Tamiya 1:24 Ford Mustang GT4 (24354)
    April 2020
Posted by Eaglecash867 on Saturday, October 10, 2020 10:02 AM
Dip in PFC first, and make sure you shake off all of the excess before leaving it to dry.  I put my freshly-dipped parts on a sheet of printer paper (since its lint/dust free) and cover with an upside-down Gladware container.  You can take the container away after about a day.  I usually let the PFC cure for at least 4 days before messing with anything.
Not sure about the context of what is meant by painting the bottom edges of the canopy black, but I definitely paint the inside and outside of the canopy frame with black first.  That way it looks like an actual frame, rather than a colored line on plexiglass.  It also eliminates the translucent appearance of not doing that before the final color goes on the outside.  In the case of my F-16CJ, I used X-18 (semi-gloss black) for this step.  Then the first mask on the outside came off and the second mask on the outside went on, slightly offset from the first mask to give a thin semi-gloss black line between the clear and the final color.  This simulates the sealant that goes around the canopy, between the frame and the glass.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    October 2016
Posted by Mrchntmarine on Saturday, October 10, 2020 3:10 PM
Eaglecash867
Dip in PFC first, ..........
Not sure about the context of what is meant by painting the bottom edges of the canopy black, but I definitely paint the inside and outside of the canopy frame with black first.....
Still not sure....  You mention to dip 1st then to paint 1st???  Should i dip, dry then paint or paint the bottoms 1st then dip then do the frame?
I read in an article in FS Mag on an aircraft build where the author mentiones painting the bottom edges of the canopy to make it more realistic looking.  Of course now i cant find the article!  Thanks!!
Keep on modeling!
All the best,
William
    October 2016
Posted by Mrchntmarine on Saturday, October 10, 2020 3:13 PM
Tubosteve
tks Steve - to confirm, you paint over the PFC or Future?  Wm
Keep on modeling!
All the best,
William
    April 2020
Posted by Eaglecash867 on Saturday, October 10, 2020 4:25 PM
Mrchntmarine
Eaglecash867
Think of the two paragraphs as a sequence.  PFC first and let that cure, then the painting sequence.  Wink
    February 2017
Posted by Tubosteve on Saturday, October 10, 2020 5:26 PM
Mrchntmarine
I paint over the cured/dried Future. (Actually don't know what PFC is!?)
    April 2020
Posted by Eaglecash867 on Saturday, October 10, 2020 6:09 PM
Tubosteve
PFC is Pledge Floor Care.  Its what they started calling Future here in the US.
    October 2016
Posted by Mrchntmarine on Saturday, October 10, 2020 10:33 PM
Tks all..,,  Just checking to make sure I got it right.
Keep on modeling!
All the best,
William
Posted by Don Stauffer on Sunday, October 11, 2020 7:15 PM
The problem with painting the bottom edge of the canopy is that it is usually the gluing surface.  If you do paint it, make little dimples through the paint with a tiny drill.  Else you will get a weak bond (drill holes through the mounting surface too if it is painted.
