Trumpeter Grumman F6F-3 Hellcat 1/32
    January 2015
Posted by Aggieman on Saturday, October 31, 2020 11:17 PM
Here is my latest build, one of my all-time favorite warbirds and my favorite USN fighter (by a hair against the F4U Corsair) - Trumpeter's F6F-3 Hellcat.
Right out of the box, this 'cat can be built as either David McCampbell's Hellcat, or Alex Vraciu's.  McCampbell was the leading Hellcat ace with 34 kills, while Vraciu chipped in with a tally of 19.  As a voracious reader of WWII history, I was well familiar with both men, but opted for Vraci's "white 19" because of the famous photo of Vraciu recounting his big day early in the action that would later be dubbed "The Great Marianas Turkey Shoot".
In doing some pre-build research, I ran into some photos of the actual Hellcat that I planned to build that revealed a pretty big problem with the kit.
And then this painting (not necessarily conclusive until I found the above photos):
One final shot of the famed aviator:
These photos and painting indicate that Vraciu's Hellcat sported a big, white 19.  Yet, Trumpeter thought it acceptable to sell a decal sheet with its kit featuring BLACK 19s. The kit decal sheet failed to include any of the kill markings, or the Felix the Cat squad logo.  I consider this to be a total fail on Trumpeter's part.  I almost opted for McCampbell's bird, which seemed to be more accurately represented on the decal sheet, until I found a Techmod release that did include a complete set of accurate markings for Vraciu's Hellcat.
Strike one for the kit.
As for the plastic, I'll give it a second strike for one issue:  the plastic primary wheels are far too large for the narrow gauge tires.  I had to sand away a whole lot of plastic to get the tires to fit acceptably over the wheels.
But that's as far as the baseball analogy will go.  This is a pretty good kit overall.  Not Tamiya quality, but I really didn't encounter too many issues in building this beast.  The tail wheel is notoriously fragile, and I actually broke it this morning while I was wrapping up construction.  Easy enough to repair, but if you have any eye on building this Hellcat, keep in mind that you are forced to install the rear wheel early on, so take steps to protect it as best you can.  I kept it wrapped in tape (but this morning had removed that protective tape...)
The wings can be posed extended or folded.  Since I built my Hellcat with wings extended, I can't comment on any difficulties in mounting the wings folded back.  The extended wings, however, come with some tricky fits.  Nothing major, but a portion of the wing is like a peninsula that you should take care in not snapping off (this is the outer portion of the inner wing section forming the wheel well, where there is an access panel that you can display open or closed that butts up to the outer wing section).
My primary paints came from the Vallejo box set for USN and Marine Corps aircraft 1940 - 1945.  This Hellcat sported the tri-color camouflage scheme the Navy utilized in 1943 and into the first part of 1944 of insignia white, intermediate blue, and dark sea blue.  Everything went just fine for those first two colors, but when I started painting the dark sea blue, I thought it looked rather more like a dark grey than a dark blue. I found an older bottle of US dark sea blue by a manufacturer called "The Color of Eagles" that looked more the part.
I mixed up black, grey, and brown to spray the distinctive exhaust stains, and augmented that with some Tamiya weathering compounds.  I lathered the entire airframe with Flory wash, and I used some AK Interactive streaking grime across a lot of the underside.  The entire top side got a bunch of ground-up pastels to give her the worn look that I was striving for.
I was purposeful in leaving off both the drop tank and the bombs that came with the kit.  Probably a result of that painting that I show above.
Build photos:
The kit comes with a tractor used to move airplanes around on the carrier deck or in the hangar bay.  The tow bar does not actually mount to the tail wheel (it's too wide).
I neglected to take a picture of the engine prior to installing the cowling, but I did add a bunch of wiring for the ignition wiring.
Next up is a 1/32 two-fer:  Revell's F4U-1A Corsair in a 1960's era boxing, and Tamiya's F4U-1 Birdcage Corsair.  I hope that these two will close out my busy modeling year.
Posted by keavdog on Saturday, October 31, 2020 11:22 PM
Nice job and thanks for the history.
Thanks,
John
    August 2014
Posted by goldhammer on Saturday, October 31, 2020 11:38 PM
Nice 'Cat.
    January 2020
Posted by wpwar11 on Saturday, October 31, 2020 11:49 PM
I think it's my favorite USN fighter too.  I got Eduards F6F-5 coming soon.
The exhaust staining on the bottom is AK interactive?  Is it applied with an airbrush or dragged with a brush like oils?
    August 2013
Posted by Jay Jay on Sunday, November 1, 2020 6:33 AM
Thanks for all the history and accuracy tips. I'm endevering to take it all in A stellar rendition of Varaciu's ride, I hope mine comes out near as good.
    June 2017
Posted by Chemteacher on Sunday, November 1, 2020 8:31 AM
Another beautiful job. I especially like the weathering and streaking. Nicely done.
On the bench: Revell-USS Arizona; Airfix P-51D in 1/72
    April 2015
Posted by Mopar Madness on Sunday, November 1, 2020 8:56 AM
How awesome. Such a beautiful finish!
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    January 2015
Posted by Aggieman on Sunday, November 1, 2020 8:58 AM
keavdog
Thanks Keavdog!
    January 2015
goldhammer
Nice 'Cat.
Thank you Goldhammer!
    January 2015
Posted by Aggieman on Sunday, November 1, 2020 9:01 AM
wpwar11
I have an Eduard F6F-5 in my stash, please share when you get yours built.
The primary exhaust staining is actually a custom mix I did of black, grey, and brown paint, applied with an airbrush.  I augmented the exhaust staining with the AK Interactive streaking grime, mostly from vents and access panels, and all along the distinctive ribbing along the rear portion of the fuselage.  That was applied with a brush and allowed to dry for about 10-15 minutes, then diluted and streaked with white mineral spirits.
    January 2015
Posted by Aggieman on Sunday, November 1, 2020 9:02 AM
Jay Jay
Thank you Jay Jay!
    January 2015
Posted by Aggieman on Sunday, November 1, 2020 9:03 AM
Chemteacher
Thank you chemteacher!
    January 2015
Mopar Madness
Thank you Chad!
    June 2014
Posted by BrandonK on Sunday, November 1, 2020 10:05 AM
Excellent work. The weathering is spot on.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    January 2015
Posted by Aggieman on Sunday, November 1, 2020 12:47 PM
BrandonK
BK
Thank you Brandon!
Posted by jeaton01 on Sunday, November 1, 2020 3:04 PM
Well done, Stephen, and a nice bunch of photos.  I did the Hasegawa 1/32 kit in Vraciu's markings.  I sat next to him at a dinner once, and told him thanks for his actions in WW II.  He was a great guy. one of the best.
John
    January 2014
Posted by Silver on Monday, November 2, 2020 11:02 AM
After market decals are the best bet.I had the same problem with my 1/24 scale Airfix Hellcat situation.Soon after I purchased the after market decals for a correct color decal application.Note that I seen a rare photo of the aircraft that showed no. 19 both sides chipping away lightly on all edges.This was about ten years ago after this post.Fantastic work on your Hellcat.
    January 2015
Posted by Aggieman on Monday, November 2, 2020 11:27 AM
jeaton01
Thank you John!
