Hi gents,
This is one of my current builds, HB's easy assembly pony. It is kind of a warm up for Revell's 1/32 Mustang which I have slowly started. It is my first easy assembly kit and also my first NMF bird so I am trying something new on this one.
I chose the easy assembly kit because I wanted to finish something relatively quickly and get to the paint job asap.
The kit comes with just a few sprues, with very little sub-assemblies as one would expect form an easy assembly kit.
The detail is minimal, only a few rivets and cockpit sidewalls have no detail at all, but the fit so far is good. The wings are not glued to the fuselage yet.
There is a minimal step on the underside where the cowling meets the fuselage. Some sanding from the inside will probably take care of that.
One very strange thing is that the vertical stabilizer is off center line for some reason (pics below).
A good little thing is the pin system (or whatever it's called) to join fuselage halves together. The same as in their P47 easy assembly kit as I've seen.
I tried to make the cockpit a little more interesting with paintwork and some weathering, but nothing special. Didn't want to spend too much time on it.
The cockpit will be closed anyway, and as I said, this is a quick build.
Thanks for looking.
Best,
Nikola
